| Professional Help Post local shops and businesses you trust and recommend. |
#21
The gas should be ok but I'll mention it to Matt tomorrow as i'm taking it in then. Bad gas would be a blessing but i can't imagine that is it given the problems two shops have had in trying to come up with a fix. The electrics were working but no spark. I'll re-post after Matt has at it. thanks, J.
J. ______________________________ '88 930S '84 944 '78 530 BMW '74 Bavaria BMW '74 260Z 2+2 '68 GTO (unfortunately the Pontiac version) '64 GTO (American muscle!) '64 Avanti R-2 '54 Austin-Healy 100-4 |
#22
coil MSD Bad green wire Computer bad ground bad ignition switch let us know. ARF
#23
The ground issue was addressed by the last shop. Matt said the coil was not putting out enough spark so a new one is needed. The issue is that this will be the third new coil in four months. Sooooo, something is causing these coils to go bad. More to follow when I hear back from Matt.
