#21
czesc andrzej. jak sie masz? chcialbym sie spytac czy to jest twoj silnik ktory zbudowales albo wynalazles? i tez jak to sie stalo ze znalazles ta strone tutaj?
pozdrowienia, dawid. |
#22
#23
Tak , wynalazlem , rozwinolem kilkakrotnie i wykonalem dwa prototypy; Kliknij na taka malol ikonke przy liczniku na stronie a potem" z jakich stron i szczegolowo" i zobaczysz kto i z jakiej strony odwiedzal moja strone. For Englisch: Please clik on little icon near counter on page an next click" z jakich stron , szczegolowo" Jeszcze raz bardzo milo i niespodziewanie Regards |
#24
#25
#26
![]() Yes, but "cylinder" ,house of seals, and "piston" are very well cooling water. And temperature this elements are only few grad. more than temperature water. Maybe no Teflon, good material e.g .VITON® Regards Andrew |
#27
What seals and lubes the sides?
#28
![]() Regards Andrew |
#29
New sound:
This engine are no sliding piston. This engine are no rotary piston. This engine are "Half rotary piston" 3 D Haf rotary piston URL Regards Andrew |
#30
Ok I can buy that, except for another question. If your oil is contained in a sealed cavity, what is the plan to replentish the supply. It will run out, be burnt off. If it seales to the body of your "cylinder" there will be some left behind as the seal sweeps away. This will eventually diminish the suply of oil. Also are you planning to use gravity to force the oil to the seals? You will need some type of pressure. You can acomplish this with an oil pump and some journaling.
I like to play the devils advocate.
