#281
#282
![]() Sent from my moto z4 using Tapatalk
#283
The way mine work: 1. Press power button to turn on. Press to turn off. There is no "auto-on" where you move the scale and it powers on by itself. My guess is that this is why the battery actually lasts a long time. 2. Press the 0[]ABS button anywhere to go into "INC" mode. Where ever you enter INC mode become the new zero. Press it again to set a new zero. 3. Press and hold 0[]ABS for 5 sec to leave INC mode and return to absolute mode, where the zero is at the closed jaws. 4. Press ORIGIN for 5 sec to reset the absolute origin of the tool. This comes preset and I've never had to adjust any of mine. This button is recessed so it doesn't get pressed by accident. Mine has a rubber flap at the top covering a USB port. Never used that.
#284
Try a dose of MiraLax daily for a few days. If that doesn't make it do #2, give me a call.
#285
It's been a very long time since I bought any tools... used to buy everything at Sears in Landmark. Real craftsman tools. Made in America.
My big battery charger 2-wheeled cart from Sears has finally crapped out after 30+ years. It has selectors for maintenance, 6amp, 10amp, 40amp and 200amp. Also has a timer dial... I sometimes need big power for the diesel pickups. Where do I get a high quality new one? What brand? Do I need Amazon or can I go get it locally? Thanks
Clarke 68 912 75 911S Gemini Blue 3.0L 10 GT3 18 S6 22 F250 King Ranch Gone: 18 F250 King Ranch 12 F450 Lariat 11 GT3RS silver 11 GT3RS white 10 Cayenne GTS 08 Cayenne S 06 997 C4S cab (2) 05 997S C2 Launch 04 M3 Laguna Seca Blue 02 996 cab 91 964 C4 82 911 SC Euro 3.0 (3) 78 911 - 3.2 77 911 75 911S 73.5 911T 73 911T 72 911T 71 911T RSR vintage racer 3.0 69 911T Kermit vintage racer 2.0 68 911 Maximum Freedom, Minimum Government http://www.lp.org/ |
#286
^ lowes has a Schumacher Electric 200-Amp 12-Volt Car Battery Charger for ~$160, sounds like what you are replacing. Similar on amazon for maybe a little less.
![]() $250 https://www.tooldiscounter.com/produ...xoCTOwQAvD_BwE
#287
My search skills are lacking tonight. I need a decent oscilloscope to read sensor output or ecu output to an alternator. Nothing complex, more is the output, there, in the expected range and consistent. Found a Fluke 123 but $$$, other option is a ds0201 nano. Seems pretty common but I've they can be hit or miss. Then I see the uscope, https://www.aeswave.com/uScope-Basic-Kit-p9621.html . Seems about as basic as it can get but comes with probes and some docs.
Recommendations on a basic scope for automotive applications? Thanks
#288
#289
Probably overkill for your application, but I have been buying test equipment such as oscilloscopes from Rigol, Hantek, and Siglent lately.
Jim ------ "2014 & 2017 Central PA SCCA Witch's Rallye - Best Team Costume Award" White/Green '91 SSM Miata #01 Silver '00 Miata Green '96 911 (993) Carrera #409 Blue '09 911 (997.2) Carrera S Cab Black '15 Yukon XL w/ '98 Trailex (Tow Vehicle) Burnt Orange '75 FJ40 Yellow '19 718 Boxster (wife regretfully sold it to fit the grandkids) Black '83 911SC Targa (regrettably sold when the second car seat didn't fit and 2nd daughter came along) |
#290
