polish engineering... hey, no laugh! - Page 25 - Dorkiphus.net
Navigation » Dorkiphus.net > Miscellaneous Discussions > Miscellaneous Discussions » polish engineering... hey, no laugh!
Old 09-15-2011, 05:11 AM
Feliks's Avatar
Feliks Feliks is offline
Feliks
Is marriage Underground Windmill of Tesla's Turbine is the optimum solution?
several cases that support the solution
http://www.imp.gda.pl/en/research-ce...less-turbines/
http://www.freepatentsonline.com/7695242.pdf
Andrew
Old 09-15-2011, 10:11 AM
flipb's Avatar
flipb flipb is offline
flipb
Originally Posted by Feliks View Post
Here PhotoStream proposal, which has improved aerodynamics and a little stiffness to the system add..
some histo:
Fairey Rotodyne - YouTube
http://www.new4stroke.com/percival.pdf
http://www.new4stroke.com/AIAA-Presentation.pdf
http://tipjet.com/tj_pho_gallry.htm
Andrew
This is at the Udvar-Hazy center of the National Air & Space museum near Dulles Airport... knew I'd seen the idea before.
2026 Polestar 4
Old 09-15-2011, 04:32 PM
Feliks's Avatar
Feliks
I also watch a helicopter at the Aviation Museum in Krakow.
But my new idea is that, with the propeller did not flow and does not charge him anything for his ends. I added a completely new air ducts, OVER propeller. Additional cables are only about 1 / 3 length of the main rotor helicopter, but they are linked to it as shown in the figure. And by the propeller Main has the best designs...
http://www.muzeumlotnictwa.pl/zbiory_sz.php?ido=72&w=a
Andrew
Old 09-18-2011, 10:50 PM
Feliks's Avatar
Feliks
If you do not want to lose a large diameter fan operating in the Venturi nozzle, you should use " internal Venturi nozzles ".
These are just two cones inside a circular tube
Their convergence must be in accordance with the Bernoulli's principle, just like a normal venturi nozzle. So must be kept laminar flow. But we gain a large diameter fan. Theoretically, the energy gain obtained is 10 times larger in relation to the windmill in a narrow place of the normal venturi nozzle....
Field cross-sections must be changed in the same function as in classical venturi
Andrew
Old 09-19-2011, 08:05 AM
Energy gain? Please explain.
Old 09-19-2011, 06:40 PM
Feliks's Avatar
Feliks
formula for power is the windmill (V ^ 3 x D ^ 2 / 1530) K efficiency ratio
If we assume the K is a constant and 1530 is also a windmill power is V ^ 3 x D^2, where D is the diameter of the fan, and V the velocity of the wind.
Using the venturi nozzles traditional, increases the speed of wind in the throat of the nozzle. Let's embrace the wind speed at the inlet with a diameter of 1 meter, 5 m / sec, then in the throat with a diameter of 0.3 meter we will have about 50 m / sec wind speed. But the diameter of the fan in the throat diameter is only 0.3 input and a normal fan with which we compare the energy. reduced the diameter of the windmill to 0.3 m in the formula for power, diameter occurs in the second power. But we have gained, however, because it occurs in the formula SPEED until the THIRD POWER. So, in total pay to reduce the diameter of the windmill, to increase the speed of the wind.
And so we have a classic increase venturi.
In Venturi Nozle Inner diameter windmill not be reduced to 0.3 m, and is referred to as 1 meter. which is three times greater than in the traditional system. lifting 0,3 m to the might of the other, we obtain the result 0.09. raising to the second power of 1 m we obtain the 1 . So, the value ~ 10 times greater. Velocity at the narrowest point in both cases remains the same (50 m / sec ). that is, in the latter case, theoretically we can get 10 times more power on the windmill located inside the Inner Venturi Nozzle, than in the classical venturi nozzle.....
Andrew
Old 09-19-2011, 08:29 PM
But were is the energy gain? can you please explain it better.
Old 09-20-2011, 03:53 AM
Feliks's Avatar
Feliks
http://www.hippocampus.org/homework-...imulation.html
Andrew
Old 09-20-2011, 08:32 AM
No energy gain, only changes in pressures and speeds.
I am sure you can clear this up.
Old 09-21-2011, 05:34 AM
Feliks's Avatar
Feliks
If you do engine tuning to the car, also only enlarge the average pressure in the cylinders and zoom in turnover. You will quickly drove this car?
Andrew
