Last PCAP HPDE of the Season! - 2014 - Page 22 - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Track Talk » Last PCAP HPDE of the Season! - 2014
Old 11-02-2014, 02:51 PM
Dandelion's Avatar
Dandelion
The line blew exiting T2 in the black session before lunch Sunday.
What's the prognosis?
2016 GT4
2012 Cayman R
2005 Lotus Elise
1994 RX-7 R2
Old 11-02-2014, 02:53 PM
hobiecat's Avatar
hobiecat hobiecat is offline
hobiecat
Sorry for the track time I cost people, but I am happy everybody managed the slide with aplomb.
Dude....it happens. Do this long enough and the track time all evens out.
Jim B.
Maryland
1987 944S - Black #303 - Zeus Suit Racing
2007 Boxster S - Carrara White - Daily Driver
"Life is too short to have a boring car"
Old 11-02-2014, 04:02 PM
All fixed. 8 count em 8 pipes pinned into block per the "shark works" procedure and cost
Old 11-02-2014, 06:22 PM
TurboPooch's Avatar
Now known as Robbie's dad
TurboPooch
Many PCA regions will not allow GT3's on track unless this issue is fixed with this procedure or by replacing the epoxied pipes with the threaded motorsport version for this very reason. We had this same problem last year in T3 and I almost collided with a Cup car when we both went spinning off simultaneously into the gravel from hitting antifreeze from a busted pipe GT3. I would like to see our techs adopt this requirement before somebody gets hurt. It is a widely known problem with a simple fix that I would think anyone that owns one of these cars would voluntarily have fixed for their own safety as well as others.
89 944 Turbo Race car
98 993 C2S w/Aerokit II
70 Boss 302
86 Mustang SVO
24 F250 SD Godzilla
Old 11-02-2014, 10:11 PM
As I understand it, all GT1 motors (turbo, GT3, GT2, 996 or 997) have this concern. Cup cars have threaded connections.
Old 11-02-2014, 10:36 PM
tbernard's Avatar
tbernard tbernard is offline
tbernard
This is correct, any GT1 based motors have the glued fittings and could pop at anytime, if not welded or pinned.
Todd
18 GT3 (VG)
Gone
18 718 Cayman GTS (GT Silver)
14 981 Cayman S (white)
15 991.1 GT3
11 997.2 GT3
96 993 Targa
96 993 C2 tracker
00 986 Boxster S
99 986 Boxster
Old 11-03-2014, 07:47 AM
Intubator's Avatar
Intubator Intubator is offline
Intubator
Might help to just put distilled water in the cooling system for a track dedicated car and empty it at the end of the season before any freeze risk occurs. Not sure if this is true but I was told that water alone is a more effective coolant than when mixed with antifreeze...
Chris Robel
1987 Carrera Targa 3.4 993SS cams, Smokey Silver Semi-Daily Driver
2006 Cayman S, Guards Red, #11 part time track addict (sometimes #12 or #22)
X-Terra, Blue
1970 911 T coupe, Bali Blue
1982 911 SC Targa, Guards Red
1974 914 2.0, Champagne Gold
1982 BMW 528e, White and rusty..
Deceased but not forgotten:
1968 911 sunroof coupe, Black
1972 VW Super Beetle, White
Old 11-03-2014, 08:10 AM
Anyone that has gone through the effort of getting the air out of one of those systems will weld or pin. Not your fathers Buick
Old 11-03-2014, 08:48 AM
GT3's Avatar
GT3 GT3 is offline
GT3
I use water in mine.
Purging air is a pain as do-it-yourself but shops have machine to make it easy.
Clarke
68 912
75 911S Gemini Blue 3.0L
10 GT3
18 S6
22 F250 King Ranch
Gone:
18 F250 King Ranch
12 F450 Lariat
11 GT3RS silver
11 GT3RS white
10 Cayenne GTS
08 Cayenne S
06 997 C4S cab
(2) 05 997S C2 Launch
04 M3 Laguna Seca Blue
02 996 cab
91 964 C4
82 911 SC Euro 3.0
(3) 78 911 - 3.2
77 911
75 911S
73.5 911T
73 911T
72 911T
71 911T RSR vintage racer 3.0
68 911
Old 11-03-2014, 12:12 PM
Intubator's Avatar
Intubator
I've done mine twice on the Cayman without any special equipment or assistance. I just had the front end as low as possible and the rear up high, popped the bleeder valve and It filled nicely. I did have to add about a quart after a cycle of driving to op temp and cooling. Of course, I would imagine the plumbing on a cayman is a few feet shorter than that of a 911 because of engine layout and may be easier burp for that reason.
Chris Robel
X-Terra, Blue
