Has anyone read the book "How to Rebuild & Modify Porsche 911 Engines"? - Page 2 - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » Has anyone read the book "How to Rebuild & Modify Porsche 911 Engines"?
Old 11-02-2005, 12:11 AM
Charlie Stylianos's Avatar
Noah,
Was this your contribution?
http://forums.pelicanparts.com/showt...hreadid=248961
Kyriakos E. Stylianos
Baglama inspired
Old 11-02-2005, 07:05 AM
realroadrage's Avatar
Trust.....but verify
realroadrage
Noah, I suggest a brief exam is in order. How about you come over and repeat the steps of the entire book with my engine? At the end of the process (assuming engine is running smoothly), I'll vouch for your technical knowledge and merit.
Everything has changed
Old 11-02-2005, 07:27 AM
Originally Posted by Jazzbass
Don't listen to them, Todd. The 911 book will be fine for you. Just take a pen and cross out any references to "cylinder 5" or "cylinder 6", change references to "cams" to the singular, replace "chain tensioners" with "belt tensioner" and "scavenge pump" with "water pump" and presto - you're set. You can thank me later.
Funny!
Old 11-02-2005, 08:25 AM
TD in DC's Avatar
TD in DC TD in DC is offline
TD in DC
Thanks Chris!
OK, I know that this is completely stupid, but I am almost giddy about the prospect of tearing this motor apart. I can't wait to understand fully what makes my new car work, and exactly what every little part does. In the future, if I hear a sound or develop a leak, I should be able to make a fairly decent guess as to what might have happened. It should also make things much easier to fix myself once the car is "demystified." Awesome.
Thank Me Dammit!
Old 11-02-2005, 08:36 AM
yes you'll probably be able to tell that #6 is a little loose
Old 11-02-2005, 08:38 AM
TD in DC's Avatar
TD in DC
LOL, bastard. Oh yeah, the other two are in the back, right? Right behind the tail lights.
Thank Me Dammit!
Old 11-02-2005, 08:53 AM
Knowledge can be a double edged sword. When you know what the lump is doing and how well it is or is not put together you don't listen to it purr, you listen for and to every little burp, fart and hiccup guessing what parts, of so many to choose from, are about to go south.
So many people look at cars as almost magical machines that are not made of parts but as something more. When you know enough you look at a car as a man made origami of sheet metal made of things bolted together. Nothing more or less than a toaster or washing machine, just bigger and a bit more fun at times. You end up seeing the parts and subsystems more than the car as a whole.
All things just want to return to a 0.0 state. Sand dislikes being piled up and at every opportunity each grain inexorably heads back towards level or 0.0 and so do machines. Only when you can release you mind from the thoughts of failure mechanical or otherwise can you drive well and meld with the car and track.
Welcome to the madness!
Old 11-02-2005, 09:08 AM
I think some of those guys at the track that never open the hood have the right attitude. Ignorance is bliss!!
Old 11-02-2005, 09:13 AM
keithmckenney keithmckenney is offline
keithmckenney
entropy plain and simple
Kurt's right
don't get too deep
zen not grok
keithmckenney
99 996 tip (staying put)
90 964 targa (gone)
88 951 gone
88 911 (gone but not forgotten)
69 912 (our first but it rusted away)
94 2JZGTE
76 FJ40
14 R1200GSw
Old 11-02-2005, 09:20 AM
Funny!
Thanks. I'm here all week. Try the veal.
Very zen response, Kurt. While I'm not in the least mystified by the mechanical complexity of cars, I still have issues reconciling the zen part with my OCD part. But I'm trying.
