power bleeder - Page 2 - Dorkiphus.net
Old 12-09-2004, 10:57 AM
Thanks Kurt, I did forget to mention “bleeding the water off”. I seldom forget, but am always sorry when I do. Pneumatic air tools run better without hydraulic assist too
15 PSI is probably a better max pressure. I noticed that right around 20 PSI the overflow hose starts to “weep” where it joins the reservoir.
Old 12-10-2004, 10:22 AM
APKhaos's Avatar
APKhaos APKhaos is offline
APKhaos
Most everything's been said here, but not sure why you are needing to reeatedly pump the MPB?
My SOP for a fluid flush is:
- Fit the empty MPB and pump up to 15 psi to check for sealing.
- Fresh can of ATE into the MPB reservoir
- Pump it up to 15 PSI
- Flush all four.
I check the pressure, but very rarely need to add more. Its usually down to around 12PSI by the time the 2/3 Liter it takes to flush is done.
If its just a bleed job, its quicker to use the MPB dry - just keep an eye on the reservoir.
Tony K
PCA Potomac, Rennlist Member
89 944 Turbo
85 Carrera - Sold
TrackVision
944Cup
Old 12-10-2004, 11:50 AM
Dave, too true about H2O in the tank. When I moved mine to the shed from the shop I added a auto blow down device from HF after finding a gallon or two of nasty rusty slime water in it. (I am a bad compressor owner) BTW the HF auto unit is crap and failed real quick. I chucked it and just added a long drain line and an easy to use ball valve.
Old 12-10-2004, 01:50 PM
nova996 nova996 is offline
Freeloader
nova996
I'm pretty happy with the motiv setup, too. I don't feel like I need to pump very much. It's still effective even if the pressure has dropped a few lbs. And running it dry or with the intake out of the fluid at the end makes setting the level very easy.
But if anyone does want to use a compressor, I have a very nice billet aluminum reservoir cap (or adaptor I guess) with a brass outlet on it to connect an air hose. Anybody who wants to try it can have it. It fits the BMW reservoirs, so it should fit most Porsche ones I guess since the motiv european adaptor seems to work on everything.
BTW medical syringes work really, really well for removing excess fluid from the reservoir after changing pads, etc. I always have a few in my track bag. Feel free to steal one from me any time.
Firoze
Old 12-10-2004, 01:59 PM
That’s pretty much what I was saying. I don’t like putting the entire contents of the blue/gold in the Motive and also don’t like storing once open cans of brake fluid. I’m just paranoid about the hydroscopic issue. So I fill up the reservoir for each caliper.
How about just fitting a valve stem to the reservoir cap (with cap of course). Then you can simple use one of those “clean, dry caned air”
Wait, wait, how about modifying the overflow line to include a valve stem, pressure gauge, shut-off valve, all in one.
Old 12-10-2004, 02:16 PM
APKhaos's Avatar
APKhaos
Why am I seeing images of blown MC seals and leaking fluid??
Guess I'm paranoid about the risks of over-pressuring the atmosphere side of the system. Its really not too much trouble to hook up the MTB and be sure the system does not get an accidental overpressure. ANd you thought I was a thrill seeker!
Tony K
89 944 Turbo
85 Carrera - Sold
TrackVision
944Cup
Old 12-10-2004, 05:14 PM
jpinkert's Avatar
jpinkert jpinkert is offline
jpinkert
- Flush all four.
Same here --
- Josh
- '72 911T
- '81 SC
Old 12-10-2004, 06:11 PM
- Flush all four.
The only thing I'd add is the bleeding order: RR, LR, RF, LF.
Old 08-25-2007, 05:40 PM
Rob in VA's Avatar
Professional coach
Rob in VA
Has anyone abandoned using their power bleeder for a better solution?
BMW Spec E46 #609
BMW specE30 #609
2004 911 GT3 - Seal Grey
Old 08-25-2007, 10:58 PM
Why? They are inexpensive, easy to use and when used per the instrutions do a great job with little risk of blowing a slug of air into the system.
There are some good vacuum based systems out there but you have to use it on one end ant a top off system on the other. Now you have two things to clean. The vacuum systems also need you to pump a bunch more than a Motive or hook up to an air hose and listen to it hiss the whole time.
google Vacula. They make some very nice equpment.
Motive pressure brake bleeder Dave O Tools Needed/For Loan 1 03-24-2005 12:53 PM
Replacing a bleeder valve BSullivan Porsche Technical Discussions 20 02-12-2005 08:24 PM
Motive power bleeder Jim Richards Miscellaneous Discussions 13 08-18-2004 10:26 AM
Homemade test Gauges and Pressure Bleeder William Miller Tools Needed/For Loan 0 03-30-2004 11:54 AM
Anyone have a power bleeder I can borrow? Jim Richards Porsche Technical Discussions 5 06-18-2003 11:06 AM
