Changing valve springs - Page 2 - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » Changing valve springs
Old 11-10-2004, 05:48 PM
The intake and exhaust spring compressors are different because they use the cam cover bolts to mount to. The stud arraignment is different on the top and bottom of the cover. These will work up to Carrera. I haven't tried them on 964 but I think stud arraignment is the same but downsized to 6mm.
One thing to consider is checking the installed spring height. (Some cam manufacturers spec out closed spring pressure instead of installed height). And although you can check spring height in place it is an awful amount of work. And don't forget if you are using a very high lift cam to check retainer to valve guide clearance and coil bind. This is almost impossible to do in the car.
Old 11-10-2004, 05:50 PM
Old 11-10-2004, 06:07 PM
Thanks for the expertise Matt. The car in question has been running as for some time, for whatever that's worth. More information is trickling in, hopefully I will have more details shortly. The car needs an exhaust upgrade as it stands, I'm trying to get a grasp on what needs to be done right away and what can until a rainy day.
Old 11-10-2004, 11:56 PM
Charlie Stylianos's Avatar
Buy it, Chris. Rainy season just started. You have 3 months worth of 'rainy' days.
Kyriakos E. Stylianos
Baglama inspired
Old 11-10-2004, 11:57 PM
It's a very strong possibility. The performance/$ is way high, might be trouble.
Old 11-11-2004, 12:24 AM
William Miller's Avatar
William Miller
Do it!
Thanks! WCM (Bill)
'81 911 SC Red Targa 3.6
'08 335i Blue Sedan
'05 Chevy Tahoe green
'98 Jeep Cherokee XJ "Blue"
'01 Toyota 4 Runner "Pearl"
Darnestown, Maryland
quick question on valve adjustments Spike Porsche Technical Discussions 11 04-27-2005 09:43 AM
Valve stem failure! Mackpipes Porsche Technical Discussions 9 04-09-2005 09:33 PM
Porsche OEM or Aftermarket Racing Valve Springs Jim Richards Porsche Technical Discussions 8 11-02-2004 10:48 AM
The Beast developed a noise at VIR ... rs911t Porsche Technical Discussions 24 09-28-2004 02:26 PM
Valve Adjusting Method--Threat or Menace? targa911man Porsche Technical Discussions 9 09-16-2003 01:39 PM
