1967 912 Red Light Question - Page 2 - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » 1967 912 Red Light Question
Old 10-05-2004, 05:19 PM
Originally Posted by jazzbass
basically there is not enough excitation current to the alt at low RPMs
What do you mean As previously stated alternators require outside stimulation before they can produce the correct response. Should I have touched briefly on how the whole system is based on switching back & fourth between AC/DC
Old 10-05-2004, 05:30 PM
By "switching back & forth", do you mean "alternating"?
Old 10-05-2004, 06:06 PM
Right... not sure what the question is - I think we're saying the same thing. The excitation current is the outside stimulation. An alternators is a 3 phase AC generator, in essence, with a set of diodes that rectify the AC into DC. The stator of the alt is what produces the 14V+ of AC (then turned into DC) the car runs on.
The rotor needs an excitation current of up to 7A to produce the rotating magnetic field necessary to induce the current on the stator. Once the alternator is spinning high enough, it will feedback current from the output to "self-energize" the rotor. However, this feedback condition needs a "bootstrap" current to get started, and this is the current supplied through the alternator warning light. This is the reason why your system will not charge if that light is burned out. The issue with the older cars was that the resistance of the bulb was too high to produce enough pre-excitation current. So, putting a resistor in parallel with the bulb lowers the overall resistance of the pre-excitation circuit, producing more current (because, of course, I = V/R).
Old 10-05-2004, 06:09 PM
BTW, here is a thread from Pelican that describes the resistors needed for early cars that have the low pre-excitation current issue:
http://forums.pelicanparts.com/showt...light+resistor.
BTW, if your 912 has a generator, then none of this alternator crap applies. Like David said. generators don't need excitation currents.
Old 10-05-2004, 06:26 PM
DonNewton's Avatar
DonNewton DonNewton is offline
DonNewton
The poor guy's ears are smoking now. . .
Old 10-05-2004, 06:34 PM
Eli's Avatar
Eli Eli is offline
Eli
Jim is correct, it's most likely your belt tension. The belt should only give about 3/4th of an inch under slight thumb pressure.
I have the same problem with my '66 912. Don't have a 36mm socket to fit the generator pulley nut . Have been too busy to go pick one up. Probably will this week....
Originally Posted by Jim Richards
The prior owner lied. That light comes on when the charging system isn't doing its job. Maybe you just have a loose fan belt, or maybe it's more substantial. Best bet is have it checked. Or, you can monitor your battery voltage with the engine running. I don't know the specs for your car, but it should be 13.something volts or more.
'78 ROW SC
Duo
GONE, BUT NOT FORGOTTEN
<65 356><66 912><84 944><87 944><88 924S><87 911><90 911><91 911><99 996>
Newbie Question Regarding Bleeding Brakes TD in DC Porsche Technical Discussions 21 05-26-2005 07:54 AM
1967 912 - overabundance of caution question on jumpstart winstonbike Porsche Technical Discussions 9 10-28-2004 08:38 AM
loose rear bulbs & third brake light wiring issue. fixes red911carrera Porsche Technical Discussions 6 10-27-2004 05:48 PM
Little light in H4's William Miller Porsche Technical Discussions 9 10-11-2004 02:26 PM
Potomac Question HPDC Question Doug E Track Talk 43 09-30-2003 07:36 PM
