Front Wheel Bearing Replacement - Page 2 - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » Front Wheel Bearing Replacement
Old 10-27-2023, 07:54 PM
Originally Posted by cmcfaul@aol.com View Post
I heated the hub with a strong heat gun for at least 30 mins and pounded the old races out. Still waiting for the new parts from Vertex. Ordered on Monday and have not arrived yet. They are usually pretty fast.
If I heat the hub in an oven. How hot should it be?
Thanks,
Chris
. 350.
Old 10-27-2023, 11:03 PM
Don't use power tools to run the Sir Tools screw. A$k me how I know...
Old 10-30-2023, 08:38 PM
TurboPooch's Avatar
Now known as Robbie's dad
TurboPooch
I had a machinist pal make me a tool specific to Porsche sealed RWB that is something like this set
https://www.amazon.com/Orion-Motor-T...969059348&th=1
Using this type of tool makes this job so easy. I typically clean the inside of the bearing socket in the arm with some emory paper to get any high spots and corrosion off. Once clean, I smear a thin coat of Castrol Optimol (lithium) paste on the inside of the arm race.This keeps the bearing from binding and going in crooked. Heat it with a MAP gas torch and use the tool to pull it back in. Note the first few mm are the most important to make sure the bearing is going in straight. If it gets crooked it will peel some of the aluminum metal and may get wedged when the bearing bottoms out and you won't be able to get the snap ring or bearing cover on all the way.
Another tip is to take the dust deal off the sealed bearing and make sure it is greased properly with a good grease. There have many instances of poorly greased bearings failing prematurely due to this. Easy to do
I use Mobilth SHC220 grease for the race cars as recommended to me by a Porsche pro race team mechanic and supplier.
89 944 Turbo Race car
98 993 C2S w/Aerokit II
70 Boss 302
86 Mustang SVO
24 F250 SD Godzilla
Old 10-30-2023, 09:11 PM
cmcfaul@aol.com cmcfaul@aol.com is offline
need for speed
cmcfaul@aol.com
I did the fronts today. Put the hub in the toaster oven and heated to 375 for 30 mins. Big side went in with a few good smacks with the big hammer and another bunch of smacks just to make sure it was all the way in. Reheated and reapeated the process. Spins nice and smooth. No road test as its raining but confident its good to go.
Made sure I did not over tighten the bearing. I think that was the cause of the failed bearing.
Sincere thanks for all the help!
Chris
73 911 E
89 Carrera
Old 10-31-2023, 10:06 AM
need for speed
cmcfaul@aol.com
Precision tools of the trade
73 911 E
89 Carrera
