Where to buy stainless steel lug nuts? - Page 2 - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » Where to buy stainless steel lug nuts?
Old 03-25-2004, 11:07 AM
Bad dates!
Old 03-25-2004, 11:14 AM
Rick Lee's Avatar
Rick Lee Rick Lee is offline
Rick Lee has one HoF thread
Why would SS nuts mess up my new wheels? It's just that the OEM lugs I have look pretty beat up. They sit well inside the wheels, so are pretty much invisible. But I figured SS nuts would be stronger and less likely to snap or crumble.
2023 BMW S1000R
2022 BMW 530i
2021 MB GLA250
Old 03-25-2004, 11:17 AM
Originally Posted by david riley
Porsche uses a proprietary seating angle on their wheels. Same for most after market wheels made for Porsches. What this means is if it don’t say “for Porsche” then just say no!
Old 03-27-2004, 08:11 AM
If you are not club racing you don't need steel lug nuts. If you want to use steel lug nuts and you use anti-seize as you should be using the nuts will not rust onto the studs.
What is the need for SS lug nuts? If you really want to get steel and chrome them.
Old 04-17-2004, 11:51 AM
RoninLB RoninLB is offline
RoninLB
Default SS lugs
I have no experience w/ SS lugs. but I have been using SS for exhaust nuts for a very long time.
SS is more brittle to begin with. The quality of SS nuts varies. Using good SS on exhaust requires a bit of technique and is not usually recommended. On exhaust the SS tends to work its way loose, thus the technique to prevent this. The mag expansion and contraction of the bolted area would only magnify the possible problem of SS wheel lugs coming loose. The factory lugs are designed to expand and contract with the Fuchs.
and FWIW.. a few years ago I read that the aftermarket stock looking P lugs were NG.. in other words I had to buy a new set from Stoddard for the security.
I'm not a pro.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x 6
Where to get stainless steel An fuel lines, Marc A? flatsixcrazy Miscellaneous Discussions 14 05-05-2005 04:12 PM
A dorki will need help in the AM... broken lug nuts Lucky Track Talk 6 03-20-2005 08:32 AM
Speedometer off, or am I nuts? OldTee Porsche Technical Discussions 8 09-09-2004 01:51 PM
Steel or Aluminum... swftiii Miscellaneous Discussions 26 07-20-2004 12:54 PM
Stainless Steel Toolbox 87turbolook911 Miscellaneous Discussions 6 11-05-2003 08:41 PM
