996 brake question - Page 2 - Dorkiphus.net
Old 08-07-2017, 04:16 PM
Le Cochon Volant's Avatar
Le Cochon Volant Le Cochon Volant is offline
Le Cochon Volant
Not the nannies. I drive with TC off and Martin is correct; that's all I have.
Holder
1969 911S
1999 996 C2 Coupe (The Flying Pig)
2016 GT3 Cup
2015 GT3
1988 951
1989 944 S2
2002 Boxster S (project)
1972 914 1.7
2013 Cayenne Diesel (wifey's DD)
2007 E350 4matic wagon DD
2008 Chevy 3500 dually tow truck
Old 08-07-2017, 09:34 PM
BikePump's Avatar
BikePump BikePump is offline
BikePump
'99 aint got no nannies.. weird - those temps are high - min run well under 400
Carmine 1999 996 Carrera - White
Pepe - 2011 Carrera S - Grey
Previously:
The Vaporizer 2009 Carrera Metallic Black
Totaled by the Police: 2009 Carrera Black
"Racing isn’t supposed to be stodgy. It’s supposed to be so goddamn wonderful batshit you can’t stand it, all noise and rumble and burning money and cavitating testicles."
Old 08-07-2017, 09:39 PM
Mark Hubley's Avatar
Mark Hubley
Yeah, but you don't use your brakes that much. You just let the wildlife slow you down
2015 Cayman GTS
2012 Mustang GT
2023 Jetta Sport
2016 F-250
Formerly owned Porsche/BMW:
1986 944 Turbo
2006 325i
2000 911
1987 924S
1999 Boxster
1986 944
Old 08-08-2017, 09:10 AM
TomChan's Avatar
TomChan TomChan is offline
TomChan
I have a theory, this is only a theory, I have no fact to support this besides experiencing unusually high rear pad wear rate on the '99 996 C2 that I've owned and also on the '99 996 C2 that my brother owned. My theory is this car does have some sort of electronic rear brake intervention built-in but has no switch on the dash to change the threshold of the intervention. I did noticed that when I put a biga$$ TPC front sway bar on which pretty much eliminated corner exit power induced oversteer the rear pad wear rate was significantly reduced.
One way to find out for sure, which I didn't try when I had the car and before putting the bars on, is to check the temp after a session by driving with a one-one thousand mental count before throttling for exit.
Old 08-08-2017, 09:45 AM
BikePump's Avatar
BikePump
Interesting... i do have the "big ass bars" on mine so that could explain and support your theory. the other thing to consider is the rear pad compound. I tried some soft rear brake pads once and they ran much hotter. what compound are you using?
Previously:
Old 08-08-2017, 10:07 AM
TomChan's Avatar
TomChan
Back when my brother and I ran 996's we used Pagid Orange and then switched to Yellows.
I think that "IF" my theory holds water the type of pads used won't change the temp much if the rear brakes are electronically commanded to drag to reduce slip angle on exit. Which reminded me of a particular incident at which a racer that I know(no name) had his first experience driving an non-manual shifting race car practicing left-foot braking. By lightly resting his left foot on the brake pedal the rear brakes over heated and race pads got consumed in less than one session.
In this "IF" scenario, having an effective limited-slip diff would make a difference as well.
Old 08-08-2017, 09:27 AM
How you go about measuring temps matters greatly in the case of brakes. The temp changes are so fast that numbers don't tend to relate well unless methods are the same to high degree. There might be a big difference in temps but there might be a big difference in sampling methods too. Likely a bit of both.....
Old 08-08-2017, 11:20 AM
qwk_croc's Avatar
qwk_croc qwk_croc is offline
qwk_croc
Get some data before making any changes. the numbers you see from an IR gun in the paddock isn't going to be very accurate. Use temperature paint on the rotors and the pad backing plate. That stuff can be quite expensive though. Another (much cheaper) option would be temp stickers on the calipers:
https://www.mcmaster.com/#temperatur...cating-labels/
https://www.mcmaster.com/#5950K31
Steve
2009 Cayman S
Old 09-30-2017, 11:56 AM
Diverzeusy Diverzeusy is offline
Diverzeusy
GT3 air deflectors that clip onto the lower suspension arm, same as the front ones, get more air in that area, if you want part numbers, let me know ��
