Changing carpet on a 911 - Page 2 - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » Changing carpet on a 911
Old 12-15-2003, 09:31 PM
estrellajon's Avatar
estrellajon estrellajon is offline
estrellajon
I assume there is a lot of fitting before gluing involved but is there cutting as well to make it fit right?
Kurt, you mentioned contact cement. Thats like rock hard afterwards isn't it. Will like 3M spray adhesvie work?
Jon Estrella
Werk 1 Euro 930S
K27-7200, Kokeln IC @ 1 bar boost., B&B front mount oil cooler, B&B headers and exhaust.
Old 12-15-2003, 09:36 PM
Parenn911's Avatar
Loose Lips Sink Ships
Parenn911 has one HoF thread
Use contact cement to install carpet
Jon, 3M makes a strong aerosol contact cement, my friend and I used it to change the headliner on his 911. Here's a link to it and other adhesives, http://products3.3m.com/catalog/us/e...er/output_html
I am not sure whether a spray contact cement or a gel contact cement is preferred. Maybe Kurt or Jim might know which is best.
Old 12-16-2003, 04:06 AM
Spray is for different app and as you need to apply the cement to both surfaces being bonded you will get it all over the inside of the car via overspray. The contact cement to use is the kind that comes in a can and you apply it with brushes and rollers just like paint. You can get it at Home Depot. Don't use it inside enclosed spaces or you will start to see pink elephants and purple cars !
Old 12-16-2003, 07:18 AM
Jim Richards
I bought my carpet kit from Pelican Parts and the pieces fit pretty well. Only needed to mess around with a couple of them. The only cutting was for making a hole for the shifter. The two pieces (one per side) that have molded in map pockets and if I recall correctly, the pieces that go under the door thresholds need to be glued into the channel that your doors' weatherstripping fit into. SO, I'd plan on replacing weatherstripping while your in there.
Old 12-18-2003, 05:03 PM
chuckw911e's Avatar
chuckw911e chuckw911e is offline
chuckw911e
I did the carpet in my old 78 targa. I found getting the map pocket carpets installed to be the most challenging. Not the door pockets, but the pockets that are at your ankles. Ifyou look closely you'll see that the vinyl goes behind the weather seal at the hinges for the doors. I guess it is hard to explain! Anyway....look at your front door hinges and you'll see what I mean. I recently saw a tech article (pelican maybe) about how to get this right. Other than these sections the rest is easy aside from stripping the old glue and regluing. Stripping is the worst (or best) part because of the fumes. But once your are done...it will look like you have a new interior. Great upgrade that you'll appreciate every day.
Chuck
1981 924 turbo w/S1 engine & g31 transmission. Water-cooled intercooler.
Old 12-18-2003, 11:07 PM
estrellajon
Thanks chuck. I guess it will be a project that I just need to jump into.
Jon Estrella
Werk 1 Euro 930S
Need help changing brake rotors rs911t Porsche Technical Discussions 25 03-21-2005 05:43 AM
Getting glue off after pulling the carpets Eli Porsche Technical Discussions 27 01-19-2005 05:11 PM
Changing valve springs cmartin Porsche Technical Discussions 15 11-11-2004 12:24 AM
Where to buy a carpet set? William Miller Porsche Technical Discussions 8 05-03-2004 11:53 AM
Anybody ever dye carpet? William Miller Porsche Technical Discussions 0 10-02-2003 12:11 PM
