Need help with my first oil change for 2003 Boxster-S - Page 2 - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » Need help with my first oil change for 2003 Boxster-S
Old 12-23-2015, 02:46 PM
No lift? I do not comprehend those words
Old 12-23-2015, 02:48 PM
Old 12-23-2015, 03:22 PM
Dandelion's Avatar
Dandelion
Originally Posted by 86911TLCAB View Post
is this guy telling you to leave your ebrake on while going up the ramps? I back up ramps all the time and have never done that. I suppose it helps from too much power to the wheels going in reverse..interesting...
I've done that before, and it works. I've also started in second gear when going the front ways up the ramp on FWD and AWD cars.
As you say, it helps smooth out the car motion.
2016 GT4
2012 Cayman R
2005 Lotus Elise
1994 RX-7 R2
Old 12-23-2015, 03:24 PM
Dandelion's Avatar
Dandelion
IMHO, that's a better approach so that oil from the front mounted cooler(s) can drain back. Front up slightly more than rear prolly even better.
Does the Boxster have front mounted oil coolers? I thought they were all oil-to-coolant coolers mounted on the engine crankcase...
2016 GT4
2012 Cayman R
2005 Lotus Elise
1994 RX-7 R2
Old 12-23-2015, 03:34 PM
Looks like you're correct. I always thought the oil ran up front, too, but it appears that only coolant radiators are behind the front bumper.
Old 12-23-2015, 04:41 PM
trytryagain's Avatar
trytryagain
I am only familiar with my 981, but does the OP also need a special socket to fit the oil filter housing cover? I think I got mine from Suncoast along with the filter, o ring, and replacement drain plug.
Jim C.
1971 914 (back in the day)
Old 12-23-2015, 08:23 PM
Intubator's Avatar
Intubator Intubator is offline
Intubator
I don't think there is a front mounted oil cooler on those. The two radiators in the front are engine coolant only, center too if it's an automatic. If there was a front oil cooler it would likely be thermostatically controlled and difficult to get the oil out b/c the thermostat would begin to close shortly after engine shut down trapping the oil in place.
Chris Robel
1987 Carrera Targa 3.4 993SS cams, Smokey Silver Semi-Daily Driver
2006 Cayman S, Guards Red, #11 part time track addict (sometimes #12 or #22)
X-Terra, Blue
1970 911 T coupe, Bali Blue
1982 911 SC Targa, Guards Red
1974 914 2.0, Champagne Gold
1982 BMW 528e, White and rusty..
Deceased but not forgotten:
1968 911 sunroof coupe, Black
1972 VW Super Beetle, White
Old 12-24-2015, 12:36 AM
987kmns's Avatar
987kmns 987kmns is offline
987kmns has five HoF threads987kmns has five HoF threads987kmns has five HoF threads987kmns has five HoF threads987kmns has five HoF threads
No front mounted oil coolers.
Yes, the OP does need the special oil filter housing socket, which can also be had from Pelican, ECS, Suncoast, etc. A generic strap wrench can be used in a pinch.
No idea why you would leave the e-brake on while going up ramps. You can easily control things with the clutch. The ramps also have a lip, so you won't go off the end unless you try really hard.
+1 for easy DIY.
+1 for getting Mobil 1 at WalMart where it is cheap. Get 2 5qt jugs.
Mihnea
2007 Cayman S Track Car
2004 911 GT3
2016 Cayenne S
2017 Macan S
2008 Cayenne S - Sold
2011 Boxster S - Sold
2007 Boxster S - Sold
2001 Boxster S - Sold
Old 12-24-2015, 07:37 AM
This thread is making me think a $200 8 quart and filter oil change sounds reasonable.
Old 12-24-2015, 10:33 AM
No kidding. Over complicate the most mundane task, the dorki way
