billc you have me scratching my head now
what is the difference between less lift and more down force? this weekend was the first time i have even driven a cayman at speed the difference from my 06 boxster s was amazing on many levels however, i could feel the rear end lift and the front end dance at speeds approaching 130mph at various points on track - so much so that i backed off a bit several times
#12
Less lift = there is still less overall weight on the wheels at speed.
Downforce = more overall weight on the wheels at speed. ed
#13
It was pretty windy around here. Could you have been feeling wind gusts, especially on the back stretch, which is very exposed?
#14
^ if you really want to feel those gusts (which I thought were fairly minor last weekend) drive my Golf! It's a box with wheels.
John V 2024 BMW G87 ///M2 (Next 444) 2021 Toyota Supra GR (The Bupra, Other 444) 2016 BMW M235 2015 Porsche Cayenne Diesel 2007 Cayman S, #444 2013 Golf R 2012 BWM x5 2017 Mazda MX-5 Club 3 time DE Parade Lap Champion #BestInstructorEver - Unknown |
#15
yes, that too
#16
Downforce = "negative lift". Just at a high level: So, every production/sports car produces lift at speed. i.e., they actually get lighter the faster they go (usually by many hundreds of pounds at 120mph). Only the most sophisticated, aero-focused race cars are actually producing true downforce at speed (i.e., making the car get heavier at speed). The "wing" on the Cayman R allows better flow than the little speed-activated spoiler on the normal models. But at best, it's still not really impacting downforce. Think of it more as a stabilizer -- it will help make your car feel more stable thanks to more efficient flow, but because its impact on the car is still extremely small, it's not worth saying the wing is capable of any appreciable amount of downforce. It does look good though!
#17
http://en.wikipedia.org/wiki/Aerodynamic_lift It doesn't take much of an airfoil to create a huge amount of lift. Look at the small wings on some of the commercial jets and how much weight they can lift. By having a wing on the rear it creates downforce through aerodynamic lift but inverted. To say you can get more downforce with less lift is not a valid statement. It probably also aids, and this is only a guess, to reduce induced drag from the large rear end of the car, and yes the rear end does create drag.
Like Otto, I found at about 120mph in my Cayman S that the front end began to lift. At 140 I felt it was time to pull back on the stick and go airborne but I'll save that for the airplane. I found some front splitters on Ebay in the $300-$400 range. I need to get these on my car as well. My buddy Scott from PA, also at VIR, added a Cayman R wing to his 09 S. I'll ask him what he did to deactivate the automatic wing and pass it along. When the discussion of lift comes up it should also include a discussion of angle of attack and drag. So here is something for you to ponder regarding drag. Which has more drag, a round bar or a rectangular bar......and why?
Mike 14 981 Cayman S Wall of Dearly Departed Loved Ones 07 987 Cayman S 03 996 86 944 74 914 78 924 Bro Code Rule 43: When a Bro learns another Bro has been in a traffic accident, they must first ask what condition the car is in. |
#18
this is from the cayman aerokit ii install pdf....
7 Concluding work 7.1 Code “Fixed spoiler” using the PIWIS Tester 9718 . 7.1.1 Select “Rear” control unit group and press •>>“. 7.1.2 Select “Coding” menu item and press •>>“. 7.1.3 Select “Fixed spoiler – not installed” in the menu and change the coding by pressing •>>“. 7.1.4 Switch from “not installed” to “installed” under “Change coding”. 7.1.5 Write coding with •F8“. 7.2 Read out the fault memory of all control units, correct any existing faults, and then erase the fault memory. Working Time: 66 58 31 03 –Installing Aerofit for Cayman, complete (1 x)– Includes: Removing and fitting spoiler lips on front apron, removing rear spoiler drive, partially disassembling rear lid and fitting rear spoiler. Labor time: 340 TU May
#19
Getting light at both ends means the car is still fairly well balanced. Adding a better wing or spoiler at the back without doing something on the front will actually make your front-end lift worse, not better. |
#20
buy a Redbull. Its cheaper and easier to install.
