shifter gone bad? - Page 2 - Dorkiphus.net
Old 07-30-2003, 01:41 PM
Dan, etal,
I was experiencing those same problems and I had installed the short shifter in my 930. So I did all the bushings in the shifter housing and also bought the Stomski coupler. After the adjustment fun, it was pure and precise. The 4 gear shifting throws are just so long in the 930.
It did help but I was nicking going into 3rd gear. this turned out to be worn synchro Ted: I have the old coupler if you want to try something else first.
Old 07-30-2003, 05:45 PM
APKhaos's Avatar
APKhaos APKhaos is offline
APKhaos
Dan,
The Stomski coupler works equally well with stock shifter or short shift kit [factory or aftermarket]. My 85 has the stock shifter, which is midway between the earlier years and the factory short shift option.
Tony K
PCA Potomac, Rennlist Member
89 944 Turbo
85 Carrera - Sold
TrackVision
944Cup
Old 07-30-2003, 11:25 PM
Mackpipes
Default bad bushings
John,
Thanks for the offer of the coupler. I'm going to try the bushing kit first to see if that fixes the problem. I took off my coupler cover plate and had a buddy work the shifter. I deffinately need new coupler bushings as well as shifter bushings. Fortunately the kit from Pelican has all the bushings. I'll keep you posted after the install. Also, I have been nicking 3rd on more spirited drives, I hope it's not a worn syncro as well.
Tony,
Have you heard any thing about the Stromski shift coupler wearing out syncros prematurely? I was told by a local shop that the factory engineered a certain amount of give (slop) in the coupler to preserve the syncros.
Ted
Ted Thomas
2003 325xi
Old 07-31-2003, 09:51 AM
Ted
my 3rd gear synchro was on the way out prior to the Stomski install. I was hoping it was not that. I was hoping all the other fixes would take care of the nicking. My motor and tranny only had 35k. In fact the original rubber centered clutch was still in tact. We just can't be sure of PO's prior shifting techniques. Good luck.
Brass Shift Coupler Bushings - Pre-Order Now! Charlie Stylianos Porsche Technical Discussions 83 12-08-2006 10:17 AM
Shifter OldTee Porsche Technical Discussions 10 11-23-2004 09:54 AM
After Market Shifter advice gjames Porsche Technical Discussions 4 08-15-2004 08:01 AM
