Cayman S (987.1) HPDE Season Prep - Page 2 - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » Cayman S (987.1) HPDE Season Prep
Old 01-29-2015, 01:47 AM
987kmns's Avatar
987kmns 987kmns is offline
987kmns has five HoF threads987kmns has five HoF threads987kmns has five HoF threads987kmns has five HoF threads987kmns has five HoF threads
Some more progress to report tonight. I am planning on shipping out my shocks tomorrow to be rebuilt, so tonight I worked on removing the rear shocks. Following is a quick overview. Here is the starting point.
Brake caliper and rotor removed.
And shock removed. In my opinion the quickest way about it is to remove the toe arm at the wheel bearing carrier and then to loosen the lower control arm at the subframe (camber eccentric bolt). Then, move up to the top, remove the three 13mm nuts that hold the shock mount in place and you should now be able to drop the shock down and remove it from the wheel bearing carrier.
The last to-do item for the evening was to strip down the shocks of all hardware. Fronts done.
Rears done.
Before shipping the shocks out, I wanted to get some practice refilling the built-in nitrogen canisters. Since I think there may be some value in sharing the procedure, I will post a separate DIY for that and link it here.
Mihnea
2007 Cayman S Track Car
2004 911 GT3
2016 Cayenne S
2017 Macan S
2008 Cayenne S - Sold
2011 Boxster S - Sold
2007 Boxster S - Sold
2001 Boxster S - Sold
Old 01-29-2015, 07:17 AM
BMAN's Avatar
BMAN BMAN is offline
Cushion Convector
BMAN
Who's doing your rebuild?
_______
Brian
'71 T
'72 E
'80 Weissach SC
'94 C2
'05 996 GT3 CUP
'11 GTS/C4S Donuts
'15 Boxster S #Blubyu
Old 01-29-2015, 10:37 AM
987kmns's Avatar
Tim Olsen of Olsen Motorsports. From my research it seems that Tim has extensive experience with JRZ/Moton rebuilds. He used to do rebuilds for Bodymotion and Napelton. He is also JRZ factory trained.
Mihnea
2004 911 GT3
2016 Cayenne S
2017 Macan S
Old 01-29-2015, 09:29 PM
Rob VN's Avatar
Rob VN Rob VN is offline
Rob VN
Default Good luck with Ti shims
Mihnea,
I've had good luck with Hard Ti shims and Pagid RS29 in not cooking the caliper seals. Interested to see what condition your thrust arm bushings are in. These are the last rubber bushings left on my car.
I've been eyeing this ERP suspension setup at Tarett
http://www.tarett.com/items/boxster~...lca-detail.htm
Probably complete overkill for my use but as they say "overkill is just about right".
Will you replace thrust arm with stock units or is there a way to get mono ball bushings for the thrust arms?
I'm also looking at these beauties:
http://www.stableenergies.com/Adjust...o/ERP-987-010/
Good luck,
Rob
2014 Mazda 3 DD
2015 Cayenne Diesel
2016 Spyder
Old 01-29-2015, 11:37 PM
987kmns's Avatar
I may give those a shot. Did it change the pedal feel much?
Yep. I'm familiar with it. It looks very nice. BMAN is running it on his Cayman. Maybe he'll comment.
Those are very nice as well. I think stock for now and maybe get the full kit you referenced above at some point down the line.
Mihnea
2004 911 GT3
2016 Cayenne S
2017 Macan S
Old 01-29-2015, 11:43 PM
987kmns's Avatar
The goal for tonight was to remove the lower control arms. Here was the starting point:
And the end point:
I also removed the thrust arm bushings from the LCAs. These are only a season old, so they were in decent shape.
More to follow soon.
Mihnea
2004 911 GT3
2016 Cayenne S
2017 Macan S
Old 01-29-2015, 11:46 PM
I have the ERP arms front and back. Only real challenge was that the spacers that go on either site of the spherical bearing way up in the body in the rear are a PITA. It is like a stack of quarters (there are three spaces on each mounting point - one thick and two thin) on either side of the bearing that has two little cones that want to push the quarters apart because of the boots. The rears had to be run all the way in (with some help) in order to get to the Boxster/Cayman length. I suspect the mount points on the 99x are a little bit further away from the LCA.
Old 01-29-2015, 11:54 PM
987kmns's Avatar
Interesting. And you combined that with RSS LCAs, correct? Any before/after thoughts?
Mihnea
2004 911 GT3
2016 Cayenne S
2017 Macan S
Old 01-30-2015, 12:15 AM
Yes, if you get the ERP thrust arms and the RSS LCAs then I think you can use the simpler thrust bearing on the LCAs since you can adjust the thrust arm length vs. adjusting the thrust bearing. Also, if you put that combo on a 986 then you don't need to get 986-specific thrust bearing (they use Porsche's confusing hydraulic and non-hydraulic term but it apparently is just a slight difference in thickness at the LCA).
I changed so many things from a worn out stock setup that I can't offer commentary of the impact of the ERPs on drivability.
Old 01-30-2015, 10:29 AM
987kmns's Avatar
And here is the reason why the control arms had to come off. To install these beautiful thrust arm bushings from TPC Racing. Thanks Tom!
All that can go back together once the new thrust arms arrive.
Mihnea
2004 911 GT3
2016 Cayenne S
2017 Macan S
