How To convert an old stove to a Powder Coating Oven - Page 2 - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Other Technical Discussions » How To convert an old stove to a Powder Coating Oven
Old 06-27-2016, 09:48 PM
rothaus's Avatar
rothaus rothaus is offline
My PC oven worked great and I did a lot parts in there, however, the size is the limit.
So I decided to build a new oven for the larger parts.
I'm using metal studs like the those are used for office building walls.
This will be the bottom part.
I used 18 gauge sheet metal for the bottom side and reinforced the corners with the same material for the coasters.
I welded the nuts for the wheel mounting bolts at the inside, in case I have the remove the wheels.
Test fitting the framing pieces.
Insulation R13
Bottom parts is complete
Completing all the panels
And Assembly of the box.
Door is mounted, looks like a big fridge, LOL
Next, the box for the controls
PID and solid state relay, this is the same stuff I used for the small oven, works great.
This is why I have always some Ikea cutting board's in my material collection.
Connection block for tha powa
Here you go
Got the thermocouple installed
Wiring of the heating coils
And the heating coils installed.
The control box done and wired
here a picture of the completed oven
I used the inner part of an old oven where I also got the coils from, and cut out the section for the rack.
A few more details, but I tested and all is working. Looking forward to powder coat the suspension part for the 1970 911.
Cheers
Engelbert
2015 911 Turbo
2012 Boxster S
2006 Cayenne S
1982 911 SC
1978 1303 Kaefer Cabrio
1971 911 3.6
Old 07-13-2016, 09:07 PM
rothaus's Avatar
Now it's complete.
Had to put some graphics on it.
Cheers
Engelbert
2015 911 Turbo
2012 Boxster S
2006 Cayenne S
1982 911 SC
1971 911 3.6
