Leaky Sunroof on 993 - Page 2 - Dorkiphus.net
Old 05-16-2013, 03:24 PM
N Fotouhi's Avatar
N Fotouhi
I can't believe you call me cheap! Didn't you see the post about having sealant designed to handle the vibration? What's it going to cost you, an extra $3.00? Sheesh!
You are cheap. Otherwise, you would hire a comprehension coach
I merely stated that the sealant that the RV store sells as vibaration resistant is likely a marked up version of the HD stuff. There is nothing about my purchase intent.
Nader
There are 3 sides to every story. Mine, yours, and the truth.
91 944 S2 - Mine, Sold
7? 914-6 Vintage racer - Mine
93 964 - Not mine
95 993 - Hers - Sold and will be missed
04 GT3 - ours? Doing double duties at DE, anyway
06 987 - Hers - plan to let son use for DE - My DIY
A few others
Old 05-16-2013, 03:42 PM
Maybe you should have Caroline check your work before you post it...
Old 05-16-2013, 04:50 PM
You guys have your heads up your butts with this 'designed for vibration' nonsense.
Any good urethane or silicone sealant is designed to accomodate cyclical movement. Class 25 accomodates 25% joint movement, Class 50 accomodates 50%, etc. Stuff made for roofs of RVs are typically membranes and not joint sealants. The talk of RV roofs just confuses the issue.
As Dr. K would say, sheesh...
Old 05-17-2013, 09:46 AM
Bird watcher Bird watcher is offline
1986 911 Carrera
Bird watcher
Marine clean is the best prep cleaner I ever ran across. You could also use great stuff expanding foam to fill any voids,trim up and do a final cover up with a paint-able silicone.
Old 05-17-2013, 11:10 AM
tape the seam with helicopter tape and be done with it.
http://www.amazon.com/ISC-Racerstape.../dp/B000TPC7HU
