![]() Quote:
![]() Quote:
Lane '93 RS America | |
im really just a parts changer so im confused. I changed the passenger window off of my uncles 00 911 Carrera but now when I tried to re-program the window it wont go up all the way nor lower itself when you gently pull down on the handle. any one has any lay mans advice or instructions??
Hi there, I am new on here, I have a window problem on my 964 and found your helpful article. I have checked the switches and wiring using it. So power and switches seems to be ok and the motor is hot all the time which I guess is wrong. My problem is that I read that the window should be lowered half way to take the motor out. As the motor doesn't work I thought that I could wind it down using the tool in the tool kit but it just turns in the hole for it without engaging or moving the window mechanism, the hole is just a hole not like an Allen socket. Can the motor be removed without lowering the window? Thanks. Neil
