Suggested Brake Pad for DD - Page 2 - Dorkiphus.net
Navigation » Dorkiphus.net > Miscellaneous Discussions > Miscellaneous Discussions » Suggested Brake Pad for DD
Old 10-07-2010, 01:07 PM
I didnt see the MO, but this place lists OE parts and list price. Not sure if it's right, but it's a good reference...
http://www.swedishparts.net/ShopByVe...%20Set&mode=PA
Old 10-07-2010, 02:24 PM
Chakka's Avatar
Chakka Chakka is offline
Chakka
Thanks for the info. Called the local dealership. They use Friction Specific Pads on their Volvo's(guarantee no squeal). $54.00 per set!
Crazy thing is that means they want $450 for labor/brake bleed.........
-Mark-
99’ Carrera
15’ Cayenne Diesel
05' Cayenne S
86' 928s
14' Cayenne Diesel (gone)
13' E92 M3 Silverstone II (competition pkg.)(gone)
07'-17' Child's tuition
09' Jaguar XKR Portfolio(gone)
93' RSA Guards Red (gone)
85' Black Targa (gone)
06' M5 Indilagos Blue (gone)
01' 996 Ducati (1st porsche down payment)
Old 10-07-2010, 02:36 PM
FWIW, just beware if the calipers are goofy, as they can be on some cars. P-cars tend to have calipers that are very simple to service. But, like our Audi for example, the rear calipers use the caliper as the parking brake, as opposed to separate small drum brake assembly located inside the rotor hat, as used on P-car and many others. The pistons on Audi's rear brakes rotate in the bore to take up slack of pad wear, as well as engaging the parking brake. In order to replace pads, you need to be able to screw the piston back into the caliper to make clearance. Can be a PIA, even with the specialty tools. Confirm pad installation instructions before you dive in unprepared.
Old 10-07-2010, 02:45 PM
Who says they bleed the brakes? Sounds like a no brainer to me.
Old 10-07-2010, 03:11 PM
racer's Avatar
racer racer is offline
racer
Do they replace rotors or resurface them? most dealers nowadays assume some type of rotor work when replacing pads.
Dave
- 1970 914-6
- 2000 Boxster
- 1987 944
- 1987 924S
- 1978 911 Euro SC
- 1976 914 2.0
- 1970 914 1.7 / 2056cc
