No Start Help - Page 2 - Dorkiphus.net
Old 05-07-2008, 09:39 AM
Had a starting issue with a work pick-up truck on Saturday. In the parking lot of a nursery, bed loaded to the top with bags of fertilizer, etc. Thankfully the parking lot had a decent slope, and the truck fired up with a push start. Once I got it to my house, it would not start again. When I looked at the battery, it appeared the negative terminal had been encased in blue styrofoam. It turned out to be a massive built-up of corrosion. When I started to loosen the terminal clamp in order to clean everything up, the clamp cracked through and fell apart. Turns out the battery connection was intermittent due to the clamp failing, and it caused starting problems every now and then. Now this was an extreme case, but it shows a small electrical contact issue can cause unpredictable results, until it gets bad enough to happen all of the time.
(edit) I repaired a tiller and a pick-up truck over the last 2 weekends. That is more work then I have done to my car so far this year. I'm afraid I might be turning into a redneck
Old 05-07-2008, 01:36 PM
Parenn911's Avatar
Loose Lips Sink Ships
Parenn911 has one HoF thread
Originally Posted by cmartin View Post
Hey Pari
Lights work fine, including the hazards. Fuel pump relay is recent. I'll check the diagram again, but I dont think there is a relay in the starting circuit. I replaced the electrical half of the ignition switch last summer.
Of course, the car started perfectly a few times today.
Ok cool....that covers those areas.
How do the distributor cap and rotor look? How about the CDI box?
Old 05-08-2008, 12:54 PM
I hooked up the load tester and it read 'CH'. In snap-on speak it sounds like I have a date with the battery charger. Of course, the car has run fine since the initial problem.
Thanks for help
