914 starting problem - Page 2 - Dorkiphus.net
Old 01-12-2008, 03:54 PM
Patrick3000 Patrick3000 is online now
How old is the gas in the car? When was the last time the fuel filter was replaced?
Lucky owner of a couple 911s
1965 Honda Sport 50
markwemple's Avatar
markwemple
Jim, where is the mps on the car?
2002 C2 Cab
1982 911 SC Targa
1978 911 SC Targa
1976 911 S Targa
Formerly:
1964 scca C coupe
1965 C coupe
1968 912 Targa
1970 914/4
1985.5 944
(glutton for punishment)
Old 01-12-2008, 03:56 PM
markwemple's Avatar
markwemple
Gas is new. Mech said the flow through the filter is fine. Pressure at the pump is where it is supposed to be but he doesn't have a way of checking the pressure at a later point.
2002 C2 Cab
1982 911 SC Targa
1978 911 SC Targa
1976 911 S Targa
Formerly:
1964 scca C coupe
1965 C coupe
1968 912 Targa
1970 914/4
1985.5 944
Old 01-12-2008, 03:57 PM
type954's Avatar
type954 type954 is offline
type954
passenger side engine bay. looks like this
Old 01-12-2008, 04:01 PM
type954's Avatar
type954
...but he doesn't have a way of checking the pressure at a later point.
try to construct the pressure gauge mentioned earlier. only costs about 12 bucks; 8 for the gauge alone. checking fuel pressure at the fuel rail could decide where to go next. it's possible the lines are not connected correctly "D" - druck, "R" - return (?), "S" - suck (?) suction (?). knowing the pressure would verifly the lines are correct.
Old 01-13-2008, 08:03 AM
hberwald hberwald is offline
hberwald
Look at the following link:
http://members.rennlist.com/pbanders/DJetParts.htm
The best Djet troubleshooting guide. Just go step by step.
Old 01-13-2008, 08:04 AM
hberwald
also check out Brad's home page for lots more information...
Old 01-13-2008, 09:10 AM
BobNovas's Avatar
BobNovas BobNovas is offline
BobNovas
Check the intake manifold for air leaks. In mine, the hoses were cracked and the air leaks caused similar symptoms. Mine wouldn't run at idle until the leaks were fixed.
Old 01-22-2008, 07:36 PM
markwemple's Avatar
markwemple
Success. We now have a running 914, OK I have a running 914. The 1st problem I encountered was that the mechanic didn't have enough patience or maybe not enough spray ether. It took a while with the starter fluid to get her to stay running. Second was that only 2 injectors were firing. FInding the wire break on the 3rd was east but I haven't tracked down the 4th.
I will be needing a FI wiring harness as I don't want a buggered situation.
2002 C2 Cab
1982 911 SC Targa
1978 911 SC Targa
1976 911 S Targa
Formerly:
1964 scca C coupe
1965 C coupe
1968 912 Targa
1970 914/4
1985.5 944
Old 01-23-2008, 08:04 AM
type954's Avatar
type954
after talking with you last night, i remembered another 914 owner who might have some 1.7 stuff. he is located in falls church va. i'll pm info as i don't think i should post it.
