It's an RSA, besides "head work" what's there to do?
David I hope to arrive to my death, late, in love, and a little drunk! Just because I don't care doesn't mean I don't understand... Homer Simpson "That's what's keeping me out of F1.... Too much mental maturity...." N0tt0n Some cause happiness wherever they go; others whenever they go. CHAOS, PANIC, AND DISORDER my work here is done... Live without pretending, Love without depending, Listen without defending, Speak without offending Last edited by Trak Ratt; 09-30-2007 at 10:01 AM. |
#12
I'll give you $6K for the car.
ARF
#13
I'd recommend doing a full rebuild. Replacing rod bearings is alot cheaper than a crank. Yeah, it's painful to the checkbook, but it also gives you the confidence on the track or when you're pushing the car.
My mechanic has rebuilt a fair share of 3.6 air cooled engines. When we did mine, the p/c were all within spec, as was the crank. We did replaced everything on the top end using the existing heads. The valves for the 3.6 aren't as cheap as the 3.0's. At least we don't have 4 per head |
#14
I think it is quite possible that you damaged the rod bearings with such a healthy over-rev. You really have no choice but to crack the case.
Sorry, Dave, there is no easy or cheap way out of this. That's why it's called the "money shift".
#15
Okay, question. When I had my over-rev 5 years ago, Ivan said he did everything but split the case. He also referred to "top 2/3." Can you take off the cylinders and examine the crank from above, below the pistons?
#16
Hey, Dave. I'll trade you an almost-perfect '86 Targa...
#17
Ok, so Stephen Dubovsky came over last evening and took a look in the borescope and had a much more positive assessment than my initial impression. He said the half moon shapes didn't look like impact because every one he's looked at have a shiny "C" where the steel valve hits the aluminum piston. He thought that the half moon on mine were either the relief in the piston face itself or shrouding of the carbon from the valve on the piston, or possiby both.
So after much deliberation, I decided to button it up, put some oil in it, and try to fire it up this evening. Guess what.....it runs!....seemingly without back-fire or missed cylinders. It's loud as shit with no exhaust but seems to be running fine. Could I possibly be ok!?!? Could it have just been that one valve with the retaining nut that fell off? I'm too skeptical right now to declare victory and I'd really like to get another person or two to observe/listen to it before I decide what to do next.
Dave Formerly "RedRS" Clarksville, MD '93 Midnight Blue RS America '93 Guards Red RS America (bent & sold) |
#18
Ok, come on over and pick up your new ride.....not.
#19
Great news (maybe), Dave! Who is Stephen Dubovsky?
Everything has changed |
#20
A very nice dorki who responded to my request in the prior thread to have someone give me a hand. He goes my "smdubovsky" here.
