If you want to drive to Brookeville (near Olney) you can borrow mine.
#12
I've got one you can borrow as well, I'm in DC.
#13
just feel it w/ your hands... if you feel a bit of a lip, it's ok.
if you feel it and it's a little 'bigg-ish', you've got two more weekends if it's surprising how big the lip is, time for new rotors. |
#14
Yes, this has happened to me. |
#15
i figure there *has to* be a way to spread the pads some to clear the lip... not sure how the beemer calipers are but on the ones that came w/ my car, worse case scenario would be to remove the pad retaining pin and then pull off the caliper itself while the pads 'stay' on the rotor...
#16
Yeah, I just spread the calipers with a c-clamp to the back side of the pad and then pulled it off.
#17
calipers should be available at Lowes or home depot and sears, i know they have them at my store. possibly could put a washer on each face of the rotor to get over the lip, use the caliper to measure thickness, subtract the thicknesses of the 2 washers for the thickness of the rotor. depends on how accurate you are trying to get.
#18
Check the flea markets - I bought a really nice vernier caliper at the flea market at the Shady Groove Metro station a couple years ago for pennies.
#19
I can loan you mine if you're not near those places in VA (I'm in Potomac).
#20
You can grind the inside face on a $20 HF verner type caliper removing about 1/8th from each face except for the last 1/8th inch near the tips. Instant cheap caliper mike and faster than a standard mike
