Targa top billowing - Page 2 - Dorkiphus.net
Old 10-26-2006, 11:36 PM
The shop in PA is Willow Grove Auto Top. It's near my wife's family abode, and they advertise in Pano. But if a dorki is willing to help (how do you sew it back together?)...
Old 10-27-2006, 08:48 AM
Dave O's Avatar
Dave O Dave O is offline
Dave O
Bill,
It sounds like the glue is shot. The foam backing on the headliner is likely rotten as well. I don't recall any foam on the outer liner so that may still be good to reglue.
This is a real easy fix to DIY. With all you do on your Pcars you'll find this a piece of cake. I had no instructions when I did mine. I just took the top off, looked at all the screws and said 'He!! I can take it apart and TRY to put it back together, worst case is I can send it to someone in a box to finish for me'. As it turned out the targa top looked fine after I was done. There is no sewing involved, only gluing.
Give it a Dorki try.
Dave O'Bryan
1977 911 Carrera 3.0 Targa
1987 VW Westfalia w/ 2002 Subaru 2.5 engine at home , 1991 VW Vanagon Hightop camper in Europe, 1987 VW Vanagon Hightop Syncro camper out West, 2014 VW Jetta TDI Sportwagen
Old 10-27-2006, 10:23 AM
markwemple's Avatar
markwemple
If you can stretch canvas on a frame, you can do this. The only issue is to make sure all the hardware is in good condition. If there is no rust and little wear, you are in great shape. After rebuilding a 911 engine, this is a no-brainer!
Old 10-27-2006, 10:42 AM
Dave O's Avatar
Dave O
I'd recommend soaking the screws in PB blaster or equal overnight to help in removal. The ones on mine had some rust and needed to be 'helped' off with an 'impact' screw driver (the kind you hit with a hammer) to get unfrozen. No real problem though.
Dave O'Bryan
Old 10-27-2006, 12:47 PM
turbo23dog's Avatar
turbo23dog turbo23dog is offline
turbo23dog
Bill,
I think this may be helpful. Check it out at:
http://www.pelicanparts.com/techarti...op_recover.htm
Rich F.
2017 BMW M240 xDrive Vert
2004 BMW 330Ci Coupe (DD)
1996 BMW 328i
2006 Cayenne S
1980 SC Targa (A1R KULD)
2010 Boxster S (sold)
2000 Boxster S (sold)
73 911T Targa (sold)
67 912 (sold)
Old 10-27-2006, 08:48 PM
William Miller's Avatar
William Miller
Thanks all.
Rich that link is pretty good in showing what is there. As I suspected there is foam below the outer skin. I guess it's only glued around the edges.
Now that I understand, I think the skin is just relaxed over the years and I can't pull it tighter (fron to rear) because of the binding on the ends.
I think I just need to live with it and maybe replace the skin as another of those winter projects.
The headliner is perfect so is the skin really only $70? when was that written?
Thanks again!
Thanks! WCM (Bill)
'81 911 SC Red Targa 3.6
'08 335i Blue Sedan
'05 Chevy Tahoe green
'98 Jeep Cherokee XJ "Blue"
'01 Toyota 4 Runner "Pearl"
Darnestown, Maryland
Old 10-29-2006, 10:56 PM
Dan M2's Avatar
Dan M2 Dan M2 is offline
Dan M2
I had the same situation on my targa. I just re-stretched (tightened) the skin and was good to go. Just remove the top, partially fold the top, remove one side, tighten and screw it back together. It may take some adjusting to get the right tension but is easy to do.
Good luck!
Old 10-30-2006, 08:54 AM
William Miller
Sounds like a good quick and best of all free solution
I didn't know that the side edges were not glued. That's key!
When you tightened the side did you end up getting any wrinkles at the front and rear corners?
I'ms just wondering if I should maybe un-glue the 1st 4-6" of the front and rear edge so that I can streach the front and rear edges as I pull the sides tight?
Thanks alot!
Thanks! WCM (Bill)
'08 335i Blue Sedan
Old 11-04-2006, 09:20 PM
Dan M2's Avatar
Dan M2
no wrinkles at all. I don't recall if there were any screws on the front or rear edges. I didn't have to take up too much slack on mine but I'm sure I would've loosened any and all screws in order to tighten it up. Once you start pulling it apart you'll see how easy it is.
-Dan
Old 06-12-2008, 03:56 PM
Okay, fixing my Targa billowing is the one thing I really want to do before Watkins Glen. Who wants to help me? Who has experience in this? (hopefully, the same person for both questions).
