#141
I think that this technology is very effective. Can you imagine that by doing the same movement up and down through the traditional piston-connecting rod-crankshaft to get the same ease the movement of this vehicle?
I think that it would then be much harder work. And these four , the looks on it, they not liked to work more than need.... Can you feel it ?? Regards Andrew |
#142
However and that will had such a good humor, just take a timber and a little grease lubricated.
Do not need any oil !! Seal or Teflon or lubricated with diesel fuel. OIl = diesel fuel in this picture ![]() Regards Andrew |
#143
Some new4stroke history:
Print table of Fortran 1982 program. I could choose from 100 of these tables, each for different angular positions of crakshafts. Here is one of them: ![]() Working drawing of the head: ![]() Regards Andrew |
#144
The first windmills pumped water in America. To sustain this good tradition, I developed a little more modern sytem for the production of electric current in a similar way of pumping water.Whether American landscape views, are water sphere.I decided to add this view to the next shot where the water will be collected water so that it could give electrical energy when draining it back into the lower reservoir.
![]() This water will be pumped sphery as in the first versions of windmills, wind. The wind turbine will move a small diameter, but it is a multi-blade, placed together with the hydraulic pump in the middle of a specially constructed balloon. Balloon will be tethered, as previously barrage balloons. Only that will go along the line, hydraulic pipes, the hydraulic motor, which will be driven water pump located in the lower reservoir.The water pump will continuously pump water to sphery. Now the water falling from the lower reservoir back to the shery, will do an electric current through hydrogenerator. ![]() ![]() Every so water sphere about the capacity of 2000 m 3, and the height 100 m can give power 10 MW for 3 minutes. If filling pumps water with the one I believe loss is managing to fill waters up, we will have it 10 MW driven with wind turbine in balloons. Of course, the balloons could be filled up by hydrogen, because today we have very good material on the shell. This system could be installed in any place where electricity is needed, and thus would have limited losses on the transfer. Also low noise, and the invisibility of the rotating blades, not to interfere in coexistence with the environment.Balloons can be affixed to a height of 150 to 200 meters, where the wind is always blowing on the ground even when there is absolute silence. some links: http://media.primezone.com/cache/189/int/8385.jpg http://www.youtube.com/watch?v=mu2gl...yer_embedded#! http://www.engadget.com/2010/06/21/n...ong-endurance/ Regards Andrew On Saturday is the anniversary of 9 / 11, and make this possible, I decided to share with my good deed ,publication of this study. ![]() http://www.911dayofservice.org/ |
#145
![]() Of course, two rotate in one direction and two in the opposite direction. You must use a very light hydraulic oil. If it were not frozen in winter. Hydraulic pump in the balloon has the best power to weight ratio. All the airlines are working on the hydraulic actuators. Of course, all of the balloon must be tested in the wind tunnel aerodynamic, in order to fully match the efficiency of the 21st century. Some pictures of how to create a balloon from the inside ![]() ![]() and NASCAR wind tunnel ![]() Regards Andrew |
#146
There is a way to shorten a bit of flexible hydraulic tube...
![]() Well, if it accidentally escaped gas from the balloon and so it can be ![]() Regards Andrew |
#147
I got an idea. Try modeling a big fan and gen set on a tall pole. Much simpler to build and far greater swept area.
#148
Name : Jazz Big Band ![]() Regards Andrew Last edited by Feliks; 09-15-2010 at 10:48 AM. |
#149
Rotating Dixieland Yoda.
#150
Next Dixieland :
![]() In some tubes can be hidden anti-missile .. Regards Andrew |
