2001 Boxster S Engine (M96/21) Rebuild - Page 12 - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » 2001 Boxster S Engine (M96/21) Rebuild
Old 12-17-2014, 02:03 AM
987kmns's Avatar
987kmns 987kmns is offline
987kmns has five HoF threads987kmns has five HoF threads987kmns has five HoF threads987kmns has five HoF threads987kmns has five HoF threads
Today Ion and I tackled the IMS bearing replacement. All IMS bearing extraction tools belong to N0tt0n, who graciously let me borrow them. Thank you thank you thank you!
Here is the sequence of steps. The removal was pretty straightforward.
The original IMS bearing was in great shape. No play at all. It seems to have been lubricated by engine oil, as there was oil inside the IMS itself.
Here are the kit components being used for this install. The Pelican kit fits both single and double row IMSs, so some parts are not used. The single and double row component zip lock bags were labeled improperly. Not a good sign.
Bearing tapped in.
Spacer sleeve added.
Locking ring inserted.
In theory this should have been it. Pretty easy stuff. Unfortunately, that was not the case today. After installing the locking ring, we noticed that it was not sitting deep enough in the IMS groove. It turns out the spacer sleeve was sticking out too far and thus blocking some of the groove where the locking ring should slide in. We tried tapping the bearing farther, but it wouldn't budge. At this point, we started measuring the thickness of the spacer sleeve.
Oh oh! Thanks Pelican. We quickly touched it up with some 200 grit sandpaper, cleaned it, and sure enough, it now sits flush with the edge of the groove. The locking ring finally fit properly too. This cost us an unplanned 2 hours worth of work. Final installation.
The next step was to complete the crankshaft carrier assembly. To that end, the rods for pistons 4 - 6 had to be installed. Old and new bearings and bolts.
Aaand done.
Time to add the rest of the parts.
Completely finished.
Back to case cleaning later in the week. I'm excited about assembling the short block soon!
Mihnea
2007 Cayman S Track Car
2004 911 GT3
2016 Cayenne S
2017 Macan S
2008 Cayenne S - Sold
2011 Boxster S - Sold
2007 Boxster S - Sold
2001 Boxster S - Sold
Old 12-17-2014, 08:25 AM
Great job, man!
Old 12-17-2014, 12:15 PM
Might be worth considering an IMS upgrade WYIT. The stronger aftermarket bearings, or the oil pressure-fed bearing upgrade are popular retrofits to avoid trouble down the road.
Old 12-17-2014, 08:55 PM
Rob VN's Avatar
Rob VN Rob VN is offline
Rob VN
Default Keep up the good work
Mihnea,
Good progress, you might beat Santa Claus.
You might consider removing the seal on your new IMS bearing so it gets lubrication although I suspect this new IMS bearing may out last the car. About how much did you have to shave off of the Pelican spacer, oops I guess it was 0.04".....
I am enjoying following your project.
Regards,
Rob
2014 Mazda 3 DD
2015 Cayenne Diesel
2016 Spyder
Old 12-17-2014, 09:32 PM
987kmns's Avatar
Yep that was it, but the locking ring wasn't engaging properly before and later it did, so I felt much better about the installation.
Thanks!
Mihnea
2004 911 GT3
2016 Cayenne S
2017 Macan S
Old 12-20-2014, 09:04 PM
987kmns's Avatar
So we made a bit more progress on the engine today. Namely, we finished cleaning the 4 - 6 case half, installed the 1 - 3 case half back on the engine stand, and dropped the crankshaft carrier into it.
Here are some shots of the 4 -6 case half all cleaned up. Not perfect, but it'll do.
1 - 3 case half back on the stand.
Crankshaft carrier installed.
Engine set to U4 in preparation for piston #1 to be installed.
Mihnea
2004 911 GT3
2016 Cayenne S
2017 Macan S
Old 12-21-2014, 11:51 AM
I nominate this thread for the Hall of Fame! Please keep the pics and progress reports coming.
Old 12-21-2014, 12:20 PM
Good call. Not sure why I didn't do that earlier
Old 12-21-2014, 02:34 PM
I think that was apparent by the first page or two And at only 20-something posts(?) at the time may be the 'youngest' HoF member ever
1984 930 - 3.6L
Old 12-21-2014, 10:29 PM
987kmns's Avatar
Thanks guys for the HoF induction for the thread. Much appreciated!
Now, for a little more progress. First thing today, we got pistons 1 - 3 ready for installation. The rods were connected to the pistons using the wrist pins and all 6 circlips. Then, we replaced the rod bearings right before inserting them into the cylinders.
Next, we flipped the case 180 degrees. At the far end, you can see my ghetto replacement for a Porsche tool that is supposed to hold the crankshaft carrier in place while the case is upside down. The near end (by the flywheel) already has two permanent bolts installed, so doesn't need the temporary measure. You can see them both if you look closely. One is in the chain guide housing area and one is outside, just to the SW of cylinder 3 in the photo.
Piston #1 installed. Set crank pulley to position U4 for this.
Piston #2 installed. Set crank pulley to position U5 for this.
Piston #3 installed. Set crank pulley to position U6 for this.
Next we practiced the installation procedure for the #4 - 6 piston installation. Here we pushed piston #6 into the cylinder and used the alignment tool to set it at the correct hight where the wrist pin can be inserted. Obviously, the connecting rod is currently on the block, so wasn't used for this procedure.
And finally, here is a screenshot from the bore scope of the circlip correctly installed on piston #6. This was just a dry run. Later this week we are planning to bolt the crankcase halves together and carry out the #4 - 6 piston installation.
Mihnea
2004 911 GT3
2016 Cayenne S
2017 Macan S
