#101
Race Technologies is supposed to be sending me pdf versions of the manuals for Dash II and the DL-1, so the final stage of planning can be completed . . .
Thank Me Dammit! |
#102
That said, I like your idea better. Run the main motor fan like so: [battery] [fuse] - [fan] - [therm switch] - [ground] and the AC fan [battery] - [fuse] - [toggle switch] - [ground]. There is still the chance of running the fans with the car stopped, but I think reduced complexity in the system outweighs the chance that he'll leave the fans on and kill the battery. Quote:
That said, I'd like to know exactly how/where you're mounting the fuse/relay panel. One idea I had was to remove the glove box and mount it there, making access to fuses/relays easy. There doesn't seem to be a good piece of metal to bolt the panel to, though. Quote:
BTW, the internal DME schematics are available here on this site - I linked to them in an earlier post either on this thread or the DME relay thread.
#103
BTW, the in-out-in-out this he's talking about is not a Clockwork Orange reference. Its something that, when I realized WTF was going on, had me scratching my head. The was Porsche wired the 944 is they ran all of the main power lines through the engine bay to an access hole on the far right of the car, where the power lines went into the cabin to the main fuse box. This is the best part - the DME sits literally 3 inches from the main fuse box, right under the steering column. So - the power lines from the fuse box to the DME are how long? That's right, 4-5 feet. Why? Because instead of going from the fuse box to the DME, they actually go back out of the cabin through the engine bay, and back into the cabin via a hole in the middle of the car, then to the DME.
I'm sure there's a reason for this - giving one point in the engine bay for testing is my current theory - but its a curious design to say the least.
#104
For those of you who have yet to experience the start of a race, I can't imagine how guys without rev limiters do not blow their motors every other time, if not each time.
Thank Me Dammit! |
#105
#106
Hmmm... I don't have a lot of quams about using the sawzall for an emergency dashboard-ectomy. In fact, I quite like cutting up 944s with large power tools.
Where do you cut the dash and do you use anything to brace up the remaining part? If its easy, I'm up for it since it'll make putting in and maintaining the new wiring that much easier.
#108
) cars need a dash. Other than that:It's soft stuff. Carboard and foam and plastic. And a metal bracket at the very bottom. Light enough the center fastener behind the old speaker grill is enough to support the remainder. Enjoy. |
#109
Thank Me Dammit! |
#110
