996 rear shocks - Dorkiphus.net
Old 09-29-2006, 08:58 PM
slbates's Avatar
slbates slbates is offline
slbates
Default 996 rear shocks
Anyone her know if you can change the rear shocks on a 996 without using a spring compressor? Any tips, tricks? I changed them on my previous 911, but it had torsion bars not coilovers.
Thanks
Steve
996 GT3
996 C2 (gone)
911SC (gone)
Old 09-29-2006, 09:18 PM
Factory 996 Manuall available here: http://www.dorkiphus.com/porsche/showthread.php?t=10816
Search is your friend!
Old 09-29-2006, 10:33 PM
slbates's Avatar
slbates
Thanks. Good thing I have FIOS. Bad thing is I now need to buy a spring compressor.
Steve
996 GT3
996 C2 (gone)
911SC (gone)
Old 09-29-2006, 11:29 PM
87turbolook911's Avatar
87turbolook911
I didn't need a spring compressor when I replaced my OEM springs to H&R.
Just un bolt the three top nuts and bottom bolts of the strut. Everything will simply fall out.
Complete instructions can be found on www.renntech.org
Search "suspension"
Vu
Old 09-29-2006, 11:45 PM
If you are installing shorter springs odds are you dont need the compressor, but it's surely safer.
Old 09-30-2006, 01:10 AM
If you find that you need to compress the springs have some one sit on the back of the car or jack the susp on one side then the other to compress. Tie the spring coils using strong wire. Coathangers work well. Unload suspention and springs will be loose. Better way is to purchase $10 spring compressor or borrow my crappy $10 spring compressor.
Old 09-30-2006, 05:16 PM
good tip! I also have them.
Old 10-01-2006, 12:11 PM
slbates's Avatar
slbates
Thanks all. I plan to tackle this next weekend.
Vu, how long did it take you to do the rears?
Steve
996 GT3
996 C2 (gone)
911SC (gone)
