Help! Is my head stud broken? - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » Help! Is my head stud broken?
Old 03-26-2006, 04:04 PM
88carrera's Avatar
88carrera 88carrera is offline
88carrera
Unhappy Help! Is my head stud broken?
I was changing the oil today and noticed seepage around cylinder 6 on my normally bone dry engine--man what a horrible feeling to see that.
Wishful thinking here, but does anyone know of maybe a crankcase or breather hose attachment is in that vacinity? I'm praying it is a leaking hose and not a headstud.
Howard
2003 996TT
1993 Mini Cooper
(SOLD) 1974 Datsun 260z, 1997 911, 1988 911
Old 03-26-2006, 05:38 PM
I'm sure you mean on the underside of the engine? The breather hose is in the "back" of the engine, closest to the passenger compartment. Often, it leaks (along with the thermostat and oil pressure sender). Oil drips straight down and is often blown back by the forces of wind as you drive and it ends up everywhere. It has been my experience that where oil winds up, is not necessarily where it came from.
Are you experiencing power loss? A valve adjustments will confirm a broken headstud.
Old 03-26-2006, 06:09 PM
Check the oil cooler for leaks too, the o-rings are known to leak. Just get the mystery over with though, pop off the valve covers and check the headstuds.
Good luck
Old 03-26-2006, 06:52 PM
Rick V Rick V is offline
My wheels are blingie
Rick V
correct me if I am wrong but I thought 3.2's didn't have the headstud problem.
82SC, Lanna
97 Boxter, She named it Willy
Go Army
Old 03-26-2006, 07:02 PM
I don't think it's as chronic as the SC's but I don't see why it couldn't happen.
Old 03-26-2006, 07:46 PM
I’ve talked to several shops and they are saying that more and more 3.2 are showing up busted head studs. Probably has something to do with heat cycles and age just like the original 2.7 engines. Each generation just seems to take longer to show up!
Old 03-26-2006, 08:10 PM
88carrera's Avatar
88carrera
It still pulls strong to near redline.
I didn't notice it until I had poured in the oil, so I now have to throw away brand new oil in the crankcase.
Do I need to empty the oil tank too?
Howard
2003 996TT
1993 Mini Cooper
Old 03-26-2006, 08:15 PM
OldTee's Avatar
OldTee OldTee is offline
OldTee has one HoF thread
Drain the oil into a very clean container and save it. Some may call this penny wise and pound foolish but if you take great care in how you do it there is little downside.
ARF
OldTee
Sold 79 911SC
1991 Corvette
Capital One is the pits!
Old 03-26-2006, 11:17 PM
I just drained a few qts of M1 into some 2l coke bottles, no need to replace clean/good oil.
Old 03-27-2006, 12:27 AM
Mackpipes
Howard, I'm afraid the motor's going to have to come out.
Go ahead and order the Raceware Headstud and hardware kit. Might as well order the Raceware Rod bolt kit as well. And since you'll be in there, I'm thinking Aasco race valve springs and Ti retainers. And if you are doing rod bolts, how about some 3.4 Mahle P's and C's, and some Carrillo H beam rods. You'll most likely bump up the compression when you switch to the new P's and C's so send the heads out to Cali for twin plugging. Sure am glad to help out a fellow Dorki.
Ted Thomas
2003 325xi
