#21
We had to push it on the trailer. I removed the driver's seat and the immovilizer was just shoved in there (not attached to anything), connetected to 2 wiring harnesses but the ground wire (which is bolted to the floor) goes to the harness, not directly to the immobilizer and there's no larger brown wire in either of those harnesses. Any particular way to see if the immobilizer is grounded? Is it possible the person welding disconnected something and forgot to reconnect? If so, what would be likely? Finally, if I want to run 12V directly to the starter, I assume that would be post 3 in the photo below--is that correct? My assumption was that 12V goes to post 1, and if power goes to post 2, that closes the solenoid and provides power to post 3. My hope was to apply those 12V to a screwdriver and thread it through the space to the post/nut without removing the throttle body (since I'm assuming this is an electrical issue and I will not, in the end, need to replace the starter). Looking for feedback that this isn't stupid if I'm careful and cover MOST of the screwdriver with electrical tape... As always, thanks in advance. Peter
#22
Peter,
You can probably rule out the controller being the problem then (two connectors well connected and locked in. Ground wire connected to the nut. The ground comes back in ). Sounds fine then! GP7 (the ground nut the brown wire is attached to under the driver's seat) goes into the harness to splice SP070 and then comes back in as a fat (2.5mm) brown wire into pin 11 on one of the connectors to the control unit. So, if the harness brown is connected to the stud/nut on the chasis and the connectors are locked in then it is grounded.
#23
Just swap the "pill" from the donor key head to yours making sure to not mix them up. But since you have access to the immobilzer box, pop it open and look for corrosion on the pins and components inside.
Steve Potomac PCA Co-CI(retired) 89 944 Turbo Race car 85.5 944 NA son's 2015/2019/2020 944Cup and PCA Nat'l Champ racecar 94 968 1 of 11 Iris blue coupes 92 968 1 of 2 Tahoe Blue Cabriolets 98 993 C2S w/Aerokit II 77 911S Vintage race car project 70 Boss 302 86 Mustang SVO 24 F250 SD Godzilla "Noel spun! Noel spun! Don't do anything stupid, Dad." -the boy on the radio on the last lap of NASA race as the second place car spins behind me in T5 at Summit Point. |
#24
I posted a couple of days ago (well, I thought I posted...). After texting with Yuri, I again tried swapping the relays around on the relay board in the trunk, and this time the car started and has continued to start fine. I had swapped the correct relay the day before without good results, but it must just not have been seated properly. 3 new relays arrived in the mail today.
Now I'm working on redoing the wiring harness to move the immobilizer behind the dash (THANKS BillC for suggesting this). 2 wires coming out of the immobilized had previously been cut, and I assume some of the others are also unnecessary but since I don't have the wiring diagram I'll just move them all (11 wires coming from the engine compartment need to be lengthened. Here's a photo as I was splitting the harness - the green arrow points to the wires that need to be lengthened (several were done after this photo was taken).
