So, which of these switches would allow the engine to crank and not catch (NOT the problem here), and which would keep the starter motor (and solenoid) from doing anything at all (I don't even get a click).
I assume the following would inhibit even a click: Bad key switch Bad solenoid No battery power Clutch/Brake switches but should allow cranking if bypassed (as they are on this car) Thanks for the advice (and any corrections to this post)
Check battery voltage first. If seems good, then try to start. If voltage drops way down, then the battery is toast.
FLAPS carry remote starter switch, where you can jump the starter to bypass the ignition switch. There's also some battery testers that will assess the battery's condition, without having to turn on anything.
Thanks! Isn't O'Reilly's a midwest chain? Is there one up near you?
Fortunately, they have these at FLAPS that do exist in MoCo, like AutoZone and Advance Auto... BTW, this is all your fault, Tony. If you only hadn't sold me that seat I just had installed... I'm sure that's the problem!!
what are you trying to accomplish? Screwdriver across the terminals works too.
Does the starter get a signal to start? test light. This simple test cuts the testing in half.
#16
Get the battery tested first since it is a simple task. If ok call the shop and see if they unhooked the battery, DME, and immobilizer when they were welding on the car. If not, welding voltages can damage them...like getting struck by mild lightning. If they did, then my bet is on the immobilizer or starter relay. Eliminate the immobilizer by borrowing one with it's DME companion and key head with the chip in it and swapping out all three.
Steve Potomac PCA Co-CI(retired) 89 944 Turbo Race car 85.5 944 NA son's 2015/2019/2020 944Cup and PCA Nat'l Champ racecar 94 968 1 of 11 Iris blue coupes 92 968 1 of 2 Tahoe Blue Cabriolets 98 993 C2S w/Aerokit II 77 911S Vintage race car project 70 Boss 302 86 Mustang SVO 24 F250 SD Godzilla "Noel spun! Noel spun! Don't do anything stupid, Dad." -the boy on the radio on the last lap of NASA race as the second place car spins behind me in T5 at Summit Point. |
#17
Chris - thanks for the advice. All: does the immobilizer keep the starter from turning, or just not let the engine "catch" while the starter is turning it? I'll check with the (very reputable) shop about disconnecting the battery, DME and immobilizer before welding.
#18
Immobilizer, clucth safety switch allows power, but you will have zero starting power. No clicks at the starter, no cranking, nothing.
Turning good track cars into other people's headaches since 1990 Denis Jenkins (PCA'86) 95 318ti S54 95 318ti CS S50 02 325XIT 02 330i 98 328i 71 911T 72 914 70 Karmann Ghia, 96 f350 7.3 99 StarFlyte 13 C-Max Gone 4 356's,1 996, 4 911's, 1 912, 2 Boxster S, 5 914's, 3 944's, 3 951, 1 924S, 4 95 m3, 03 M3,95 Ti/CS. 97M345, 84 rx7ITB, ITB gti 21, ITB GTI 48, 89 325is s52,07 Z4 coupe, 69 Charger General Lee, 2 66 Cadillac verts, 1 68 cadillac vert, 87 RX7 ITS and others |
#19
Ran out of time to do much today, but put a meter on the battery - stabilized at 12.7V. Turned the key - no significant change (and still no click).
There's a good-sized electronics box under the driver's seat, looks just stuffed in there and not attached. NO puddle of water on the floor at this point, but it's been weeks since the cage mods were done. Next 2 steps try to jump power to the starter (engine is now exposed) and remove seat to get full access to what's under there. Will update. Thanks again, Dorkis.
#20
Peter,
The rear control unit is under the driver's seat. If it is not connected that's a problem. It needs to be connected (and grounded). It is keyed to the security system. Fix that first as it probably will solve the problem. Hrmmm.... just reread your initial post and you said the car started. Was this AFTER the cage (super important). Is that how you got it on the trailer, fired it up and then drove it on? If so, unless the controller came loose somehow it is less likely to be the culprit though it could still be if not grounded and it just happened to be when you started it. Still worth double checking it is connected to the wiring harness and grounded.
Martin 2011 Cayman S (Gone) - Hardtop Blechster 2006 Cayman S (DD) 2016 Mazda CX-5 (Her DD) 2002 Boxster S (Gone) - Ragtop Blechster - Pura Patina! Dorkiphus: I buy it for the articles Last edited by N0tt0N; 05-15-2026 at 02:03 PM. Reason: Clarifying if the car has started after the cage work |
