Help with Spec Boxster (starting issue) - Page 2 - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » Help with Spec Boxster (starting issue)
Old 05-09-2026, 03:12 PM
Thanks, all. I'll see if I can get a meter on the starter to check the voltage.
I assume the "safety switch" to which Denis is referring is the immobilizer. I've never actually had to deal with an immobilizer, which I assume has been moved from underneath the driver's seat. Any idea what a common "new" location would likely be? I figure I'll need to remove the roof (much easier after Bill C taught me how to install quarter-turn fasteners) and maybe the driver's seat but can't believe they'd leave it under there in a race car...
I don’t believe they are the same. The trunk switch is to stop the fuel pump incase of rear end collision. IIRC the immobilized is an anti theft .
Old 05-10-2026, 03:31 PM
So, which of these switches would allow the engine to crank and not catch (NOT the problem here), and which would keep the starter motor (and solenoid) from doing anything at all (I don't even get a click).
I assume the following would inhibit even a click:
Bad key switch
Bad solenoid
No battery power
Clutch/Brake switches but should allow cranking if bypassed (as they are on this car)
Thanks for the advice (and any corrections to this post)
Old 05-11-2026, 11:49 AM
HoodPin HoodPin is online now
Check battery voltage first. If seems good, then try to start. If voltage drops way down, then the battery is toast.
FLAPS carry remote starter switch, where you can jump the starter to bypass the ignition switch.
There's also some battery testers that will assess the battery's condition, without having to turn on anything.
Old 05-11-2026, 06:04 PM
Thanks! Isn't O'Reilly's a midwest chain? Is there one up near you?
Fortunately, they have these at FLAPS that do exist in MoCo, like AutoZone and Advance Auto...
BTW, this is all your fault, Tony. If you only hadn't sold me that seat I just had installed... I'm sure that's the problem!!
Old 05-11-2026, 07:52 PM
what are you trying to accomplish? Screwdriver across the terminals works too.
Does the starter get a signal to start? test light.
This simple test cuts the testing in half.
Old 05-12-2026, 09:23 PM
TurboPooch's Avatar
Now known as Robbie's dad
TurboPooch
Get the battery tested first since it is a simple task. If ok call the shop and see if they unhooked the battery, DME, and immobilizer when they were welding on the car. If not, welding voltages can damage them...like getting struck by mild lightning. If they did, then my bet is on the immobilizer or starter relay. Eliminate the immobilizer by borrowing one with it's DME companion and key head with the chip in it and swapping out all three.
89 944 Turbo Race car
98 993 C2S w/Aerokit II
70 Boss 302
86 Mustang SVO
24 F250 SD Godzilla
Old 05-12-2026, 11:38 PM
Get the battery tested first since it is a simple task. If ok call the shop and see if they unhooked the battery, DME, and immobilizer when they were welding on the car. If not, welding voltages can damage them...like getting struck by mild lightning. If they did, then my bet is on the immobilizer or starter relay. Eliminate the immobilizer by borrowing one with its DME companion and key head with the chip in it and swapping out all three.
Steve, can you put the wrong key in the car (with the key's matching DME and immobilizer) and start the car that way? How do you turn the key? Thanks in advance.
Chris - thanks for the advice.
All: does the immobilizer keep the starter from turning, or just not let the engine "catch" while the starter is turning it?
I'll check with the (very reputable) shop about disconnecting the battery, DME and immobilizer before welding.
Old 05-14-2026, 02:41 PM
Goggles Paesano's Avatar
Goggles Paesano Goggles Paesano is offline
Where's the beef?
Goggles Paesano
Immobilizer, clucth safety switch allows power, but you will have zero starting power. No clicks at the starter, no cranking, nothing.
Turning good track cars into other people's headaches since 1990
Denis Jenkins (PCA'86)
95 318ti S54
95 318ti CS S50
02 325XIT
02 330i
98 328i
71 911T
72 914
70 Karmann Ghia,
96 f350 7.3
99 StarFlyte
13 C-Max
Gone
4 356's,1 996, 4 911's, 1 912, 2 Boxster S, 5 914's, 3 944's, 3 951, 1 924S, 4 95 m3, 03 M3,95 Ti/CS. 97M345, 84 rx7ITB, ITB gti 21, ITB GTI 48, 89 325is s52,07 Z4 coupe, 69 Charger General Lee, 2 66 Cadillac verts, 1 68 cadillac vert, 87 RX7 ITS and others
Old 05-15-2026, 01:31 AM
Ran out of time to do much today, but put a meter on the battery - stabilized at 12.7V. Turned the key - no significant change (and still no click).
There's a good-sized electronics box under the driver's seat, looks just stuffed in there and not attached. NO puddle of water on the floor at this point, but it's been weeks since the cage mods were done. Next 2 steps try to jump power to the starter (engine is now exposed) and remove seat to get full access to what's under there. Will update.
Thanks again, Dorkis.
Old 05-15-2026, 01:45 PM
Peter,
The rear control unit is under the driver's seat. If it is not connected that's a problem. It needs to be connected (and grounded). It is keyed to the security system. Fix that first as it probably will solve the problem.
Hrmmm.... just reread your initial post and you said the car started. Was this AFTER the cage (super important). Is that how you got it on the trailer, fired it up and then drove it on? If so, unless the controller came loose somehow it is less likely to be the culprit though it could still be if not grounded and it just happened to be when you started it. Still worth double checking it is connected to the wiring harness and grounded.
Last edited by N0tt0N; 05-15-2026 at 02:03 PM. Reason: Clarifying if the car has started after the cage work
