Guards Red 2000 Boxster S on Ebay. Tiptronic is slipping. It's in Monrovia, Maryland.
Seller offered to sell for $3650. Says the Tiptronic is gone, needs to be replaced. IMS not replaced. 115630 miles. What would a replacement Tip cost and how difficult is the swap? What about the other issues mentioned? Need advice from tech folk. Anybody interested in a project? I'm at mschnittker@verizon.net - Mike in Sterling, VA https://www.ebay.com/itm/28601160792...&segname=11051 "**NEEDS NEW AUTO TRANSMISSION** Does run and drive but transmission is slipping, would highly recommend trailing the car home. Replacement tiptronic 3.2 trans can be found as low as $1000 on eBay, great opportunity for a flipper or enthusiast to get into a boxster S for way under book ($8200). The 3.2 engine, boxster S brakes and 18 turbo twist wheels are worth well over $6000 by themselves, price is firm. I’ve owned this car for about 6 months and was going to fix up but genuinely have just lost interest in the project. Strong engine, clean interior, needs some work. Below is a list of what I have found from my brief inspection of this vehicle The good: - runs and drives, registered, insured - convertible top motors work great, goes up and down automatically, no issues. - strong 3.2 engine - Clean MD title in hand, no liens - new drilled rotors/pads, almost no miles on tires, axles, battery, oil, spark plugs and tubes, air filters - car cover - original 18’ turbo twists, boxster S red calipers, Needs - Clean MAF sensor - tiptronic transmission - rear wheel bearings - radio doesn’t work - passenger seat power wire came loose from harness pin- needs repinned. - bumper respray - driver door lock cylinder has typical “spinning barrel” Come see in Frederick MD 21704, inspections always recommended and welcome. Can do over the phone FaceTime inspection as well. As always, vehicle sold as-is." |
Don't know about the tip', but $1k on eBay sounds pretty risky...
If he thinks it's worth $6k, but he's selling for 40% less, than he knows it is not worth $6k. 150k+ on a 25-year-old motor that 'runs strong' -- I would question that unless he's had it dyno'd recently. Chances are you could be looking at a motor refresh as well as the transmission replacement unless you only want to get it working a flip it.
Offer the guy 50% and then part it?
Dudley Aldie, VA 99 996 C4 Black/Black Areo 86 951 Graphite / Burgundy 2002 BMW 530i 2008 Volvo XC90 1995 Chev Astro (workhorse going-bald) My Garage Build |
Put eyeballs on the car. Bring ramps and a socket set. Put the car up on the ramps and smell the transmission fluid, is it burnt and when was it changed? The fluid may not have ever been replaced. Get the production date from the drivers door jam, early 2000 production = dual row IMSB. Don’t change it! Instead get an oil analysis from blackstone and a bore scope. You might get lucky. Lastly get the option codes from the sticker under the hood. Code 408 the wheels are worth more than the ask and finally two spray cans color matched to the paint code, front bumper cover is good as new
Ohh, I forgot bring 25 fresh newly printed hundred dollar bills, money talks
Karl Lucky owner of a couple 911s 1963 LeMans Convertible 336 HO V8 with a manual 3 speed 1965 Honda Sport 50 |
Thank you for all of the excellent comments! The Dorkiphus gang is a valuable community!
A good clue is to look for cosmoline on the engine - no cosmoline indicates it was definitely replaced.
Jeff S '14 991.1 Carrera S Coupe '25 Cayenne E-Hybrid '11 997.2 Carrera S Cab '09 987.2 Cayman S '05.5 Audi S4 '25 GMC Yukon XL '17 718 Boxster '18 718 Cayman x 2 |
See my HoF thread here:
https://dorkiphus.net/porsche/showth...031#post274031 The early tips are pcs of crap IMO. Good luck finding a used one that works (maybe there are more donors out there now a days w. the engines failed.) Best you could do is find a VW shop guy that REALLY knows the guts of them and maybe rebuild. Or just save yourself the headache and buy a different car.
Stephen www.salazar-racing.com 1970 914/6 - 3.0L GT 1983 911SC - 3.32L IROC 1984 930 - 3.6L dirt bikes (some gas, some electric), Sherco trials bike Sold: 2001 Boxster (hers), 2003 996tt x50 |
Finish the rebuild or junk the project.
We couldn't find a suitable replacement or one we could trust w/ a rebuild. Listed in on Pelican IIRC. Sold to a guy in DE(?) who was a good friend of a VW mechanic who thought they could swap some parts from those to fix it.
