Way back when I first got my 911, I replaced the shift linkage bits in the tunnel behind and between the front seats. I remember adjusting, and was never convinced I had it perfect. I thought the part I used was a special Dorkiphus made bit.
Today I was running errands and celebrating the brakes feeling healthy again, and it popped out of third. I put it back into 3rd again easily enough, but it popped out again. Could the adjustment of this bushing in the floor correct this issue? Found an article and it all came back once I opened the panel and looked at the linkage. I adjusted so the shifter is a tad farther forward and it didn’t pop on test drive. I also installed the rubber boot more securely and the gear noise was reduced slightly. Fun diy project car!
Bob 04 GT3 86 Carrera 97 318ti "Guys, I'm coming in, I have too much grip." Last edited by roundel; 07-26-2022 at 04:14 PM. |
I remember watching you redo the suspension on that car over at Kurt's many years ago. I'd already done it twice (on my car and on some brown Targa out in Manassas) so I enjoyed watching you do it.
But even stronger in my memory is watching you flog that car at Summit Point before you redid the suspension, with the car heeling like a sailboat in a strong breeze!
I had a similar problem and it ended up being worn motor mounts. Installed solid ones and problem solved.
Scott Bresnahan Purcellville Va. 2014 GTB1 World Champion 8 Time National DE champion 88 911 Cup 2021 GT4 13 Boxster S 1969 Saab Sonett 2013 Cayenne 2014 F150 Hurricane race trailer with A/C 05 Cup car 02 Koni 996 |
Pop out under load? Shifts otherwise feel good and the right places in the other gears? Might be dogged out dogs. Check for loose trans bolts on the crossover and all the mounts. Check the shifter and all the stuff in the path from hand to shift shaft. Loose worn crumbled plastic bushings?
