Merry Christmas everyone!
Just returned for the holidays from Germany and wanted to pull the Targa out of storage for a run. Started up perfectly and let it run for a few minutes. Just before taking it out, I did a quick walk around and noticed that my driver side tail light and the passenger side side marker light were out. Checking the fuses, I saw that a fuse had burnt out. Went to the store, bought new fuses, replaced, and turning on the lights burnt it out again immediately. I didn’t think that fuse ran along opposite lights like that, so I’m a little confused. Any ideas guys? I’m thinking it’s a ground wire but I didn’t have much time to investigate a whole bunch. Would appreciate any help! |
Bad factory ground won't trip the fuse. Bad ground would be no light and good fuse. Fuse blow is indicative of a short. At some point between the fuse and the intended ground, which would be after the powered device, the 12V power is grounding out.
First off what year targa do you have?
Year?
Left and right sides are different fuses so you may just have a bad bulb on one or the other.
No more little kids blowing down the stairs at 4:30 am on Christmas morning. We have to wait for them to wander down when they feel like it yawning and scratching. In the mean time....
Start by looking at the visible wiring lines in the front and rear trunks. Parked 911s are attractive to mice and they like to munch on the wires. Got mice? Open the light for the side that is blowing the fuse and take a look to see if there is anything visible. Pull the bulb out and see if there is crud in the socket or the socket is rusted up. Which fuse is blowing? #5?
