rusted new wheel studs - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Other Technical Discussions » rusted new wheel studs
Old 04-28-2019, 04:19 PM
JoeG's Avatar
JoeG JoeG is offline
JoeG
Default rusted new wheel studs
I installed new wheel studs on my CS, washed the car and one week later I noticed both the studs and nuts are rusted I don't want to paint them nor spray with a lubricant as this might effect torque specs. I'm waiting to hear back from the supplier. Anyone else have this issue? Thanks.
Old 04-28-2019, 04:35 PM
Sure all the time. I paint the wheel nuts once a year, and the studs when needed. Best to paint nuts on a separate stud/bolt so no build up on threads. Will also lessen effect on painted stud threads.
Old 04-28-2019, 05:09 PM
TurboPooch's Avatar
Now known as Robbie's dad
TurboPooch
Looks like you need to replace them with the proper length so they don't stick out so far and the eyesore rust will not be an issue...
Otherwise look into something that has some anti-corrosion zinc plating on both the studs and the nuts like these
http://www.rennline.com/Competition-...waAuW4EALw_wcB.
89 944 Turbo Race car
98 993 C2S w/Aerokit II
70 Boss 302
86 Mustang SVO
24 F250 SD Godzilla
Old 04-28-2019, 07:15 PM
jrj3rd jrj3rd is offline
jrj3rd
When I had mine in the shop a few weeks ago they recommended aerosol (spray) graphite after cleaning them. the said it would turn them black and keep them from rusting. Haven't tried yet, but trust them.
John
___________
00 Boxster S
Old 04-28-2019, 08:30 PM
It is just flash surface rust. Next time you have the wheels off wipe the studs and nuts down with some water displacement type light lube. "Dry" bike chain lube is real good. Don't spray directly, spray or wet a rag and wipe them down.
Graphite has 0 ability to resist water and prevent rust. it is slippery sheets of carbon, messy but just the ticket for some things. might not be my first reach for studs.
Old 04-28-2019, 08:32 PM
JoeG's Avatar
JoeG
First time using studs and was told I should get the longest ones. Any way they look better in the rear and needed the longer ones for the other set of wheels (18" Cayman S (II) which have a deeper recess compared to the 18" Cayman S wheels shown in the photo. Mine have a Zinc Phosphate finish. Perhaps I should blow the excess water after washing.
Old 04-28-2019, 08:34 PM
JoeG's Avatar
JoeG
Thank you I'll give it a try.
Old 04-28-2019, 09:30 PM
Fuch it -- it's a track car.
Old 04-28-2019, 10:30 PM
jhsmith's Avatar
jhsmith jhsmith is offline
jhsmith
Anti-sieze can be helpful in slowing rust but there are differing opinions on its use on wheel studs.
Jim
"2014 & 2017 Central PA SCCA Witch's Rallye - Best Team Costume Award"
White/Green '91 SSM Miata #01
Silver '00 Miata
Green '96 911 (993) Carrera #409
Blue '09 911 (997.2) Carrera S Cab
Black '15 Yukon XL w/ '98 Trailex (Tow Vehicle)
Burnt Orange '75 FJ40
Yellow '19 718 Boxster (wife regretfully sold it to fit the grandkids)
Black '83 911SC Targa (regrettably sold when the second car seat didn't fit and 2nd daughter came along)
Old 04-29-2019, 10:21 AM
arob's Avatar
arob arob is offline
Don't believe the hype
arob
My Rennline comp studs develop surface rust. Just clean them up whenever you pull the wheels. I also use graphite lube when reinstalling, but I also don't expect them to prevent the rust.
Rob T.
2006 Carrera S
2013 Cayenne GTS
