Mini Project: My 82 SC Suspension Refresh - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » Mini Project: My 82 SC Suspension Refresh
Old 10-29-2018, 09:23 AM
rothaus's Avatar
rothaus rothaus is offline
rothaus has nine HoF threadsrothaus has nine HoF threadsrothaus has nine HoF threadsrothaus has nine HoF threadsrothaus has nine HoF threadsrothaus has nine HoF threadsrothaus has nine HoF threads
Default Mini Project: My 82 SC Suspension Refresh
Finally getting to this. Over the weekend I started with the disassembly.
Disassembly begins.
I warmed up the engine before I put the car on the lift, and drained the oil.
Started at the front.
A lot of that ugly black stuff around the strut mounting.
I tried to clean up a bit of the mess.
Here is the rest of the front suspension.
All this need to be cleaned up.
Removing the original inner pieces from the struts.
Got most of the removed item cleaned up a bit.
A few more parts to clean.
The small stuff I will zinc plate, and the larger items powder coat.
To be continued.
Cheers
Engelbert
LED Lights for Classic Porsches
2015 911 Turbo
2012 Boxster S
2006 Cayenne S
1982 911 SC
1978 1303 Kaefer Cabrio
1971 911 3.6
Old 10-29-2018, 11:02 AM
arob's Avatar
arob arob is offline
Don't believe the hype
arob
Awww yeah! Can't wait to follow this one...
Rob T.
2006 Carrera S
2013 Cayenne GTS
Old 10-30-2018, 10:03 AM
Excellent, thanks for posting.
I really like your cleaning process, so much nicer to work with clean parts.
Old 10-30-2018, 10:33 AM
90% of any older car project is cleaning.
Old 10-30-2018, 10:35 AM
...that's why we all drooled over your hot-parts-washer and ultrasonic cleaners VG!!
Engelbert,
What do you use to clean your parts?
‘19 SQ5
Old 11-02-2018, 04:17 PM
rothaus's Avatar
Engelbert,
It depends. The lose dirt I usually just scrap off, wash oily stuff off with oil eater. Brake dust with Brake cleaner. Once oil and dirt is off, beat blasting before coating, plating, etc. I also have oil eater in my parts washer.
2015 911 Turbo
2012 Boxster S
2006 Cayenne S
1982 911 SC
1971 911 3.6
Old 11-02-2018, 04:32 PM
rothaus's Avatar
Continue with the rear suspension disassembly.
In order to remove the T-bars, the side skirt has to come off, which is a good opportunity to clean.
The T-bars came out without a fight.
And the inside of the tube looks clean and no rust.
Now getting the old rubber off is a PITA. One down, one more to go.
Rear suspension hardware after removal.
Got most of it cleaned up a bit.
Back to the front. The hubs are clean. I think I just give them a clear coat of paint.
Got the hardware for the front ready. Just did clear Zinc, no yellow.
Got the cross member and dust shields coated.
Started to clean the wheel wells and the areas where I cannot get later when the suspension is back installed.
More to come.
Cheers
Engelbert
2015 911 Turbo
2012 Boxster S
2006 Cayenne S
1982 911 SC
1971 911 3.6
Old 11-04-2018, 10:55 AM
Dave O's Avatar
Dave O Dave O is offline
Dave O
You may have mentioned this before but what are you doing to clean the wheel wells and under the tub? Looks great and I will want to do that to my project.
Dave O'Bryan
1977 911 Carrera 3.0 Targa
1987 VW Westfalia w/ 2002 Subaru 2.5 engine at home , 1991 VW Vanagon Hightop camper in Europe, 1987 VW Vanagon Hightop Syncro camper out West, 2014 VW Jetta TDI Sportwagen
Old 11-06-2018, 10:26 AM
Tito
86911TLCAB
looks great as always...what is oil eater?
Tito
82 911 SC with 3.2
73 RSR project
97 328is
99 328is
97 Lexus SC300 Manual
86 TL (gone)
993 (gone)
75 911S (gone)
Old 11-06-2018, 01:10 PM
rothaus's Avatar
I use a spray bottle filled with oil eater 1/2 and 1/2 water, a kitchen brush, rags. Messy work.
2015 911 Turbo
2012 Boxster S
2006 Cayenne S
1982 911 SC
1971 911 3.6
