Creating my dream 911 - Page 2 - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » Creating my dream 911
Old 06-01-2018, 01:40 PM
Modian's Avatar
Modian Modian is offline
Modian
Found some good pictures of what my car would look like if I went back to the stock color. I dig it. But I like the yellow too. Opinions?
http://www.fantasyjunction.com/cars/...d%206-Cylinder
Aaron
1993 964
2004 GT3
2017 M3
Old 06-01-2018, 01:49 PM
arob's Avatar
arob arob is offline
Don't believe the hype
arob
Originally Posted by Modian View Post
Opinions?
Light blue metallic is the best color for these cars.
Rob T.
2006 Carrera S
2013 Cayenne GTS
Old 06-01-2018, 02:09 PM
Totally subjective opinion - if I was going to paint an old 911 a different color, I'd go black.
Old 06-01-2018, 02:40 PM
no wrong answer, its your ride
I prefer silver, the metallic blue looks good too
Old 06-01-2018, 03:05 PM
spiffyjiff's Avatar
spiffyjiff
if it's simply a vote on the yellow vs. the blue...blue. def the blue. great color IMO.
Chris M.
Old 06-01-2018, 05:15 PM
trytryagain's Avatar
trytryagain
Tangerine.
https://www.google.com/search?q=pors...mQO8hLbAXN6PM:
Jim C.
1971 914 (back in the day)
Old 06-01-2018, 09:44 PM
Modian's Avatar
Modian
Originally Posted by trytryagain View Post
I like that. Orange is definitely in the running. Plenty of time to decide.
I need to decide on a look first. The impact bumpers are actually growing on me, which is kind of shocking me. I知 actually debating just removing the strakes and holes, fixing the rust at the hood corners, and touching up areas versus backdate RSR/IROC/custom whatever. Would still like to drop weight though.
I知 also going to need a rebuild this winter (5 cylinders with 10% leak, 1 with 20%). Leak seems to be from the rings. Problem is Mahle no longer makes the pistons for the 3.1, so if I need new ones then I知 hosed. So do I tear it down, check pistons and cylinders and rebuild if okay, make a 3.2ss if not, or just go straight to dropping a 3.6 in? Anyone local have a 3.2ss?
Aaron
1993 964
2004 GT3
2017 M3
Old 06-04-2018, 10:54 AM
Charlie Stylianos's Avatar
Rosewood!
Kyriakos E. Stylianos
Baglama inspired
Old 06-04-2018, 12:43 PM
racer's Avatar
racer racer is offline
racer
I like that original color.. Also like any of the Jelly bean colors -Continental Orange, Viper green, there was a nice Iroc blue as well.
My SC used to have CIS injected 3.2ss. Great torque pull but a little weak on top (above 5500rpm). Dynod at 192rwhp on a Dynopack. You might consider gearing and final drive changes to wake the car up as well. The later the car, the more fuel economy came into play.
While certainly heavy, keep the impact bumpers, especially if driving on the street. The other reason they are growing on you is 1) age and 2) everyone else goes to the longhood look.
- 1970 914-6
- 2000 Boxster
- 1987 944
- 1987 924S
- 1978 911 Euro SC
- 1976 914 2.0
- 1970 914 1.7 / 2056cc
Old 06-04-2018, 07:39 PM
Modian's Avatar
Modian
I知 a bit surprised yours only dynoed at 192. I thought they were good for low 200s at least. Did you have cams done?
I used a smoke machine on the engine yesterday, and as I expected, found several leaks. Some from the exhaust I put on, which I thought I may not have tightened right. One from the electrical plug on the idle control valve? And one from a vacuum line behind the throttle body that was attempted to be capped with a bolt.
I知 waiting on some parts now to address those and I hope it finally fixes the misfire/stumbling at partial throttle I intermittently get. Should be here in time to get it back together and make it to the C&C this weekend.
Aaron
1993 964
2004 GT3
2017 M3
