First Brake replacement - Page 2 - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » First Brake replacement
Old 12-28-2005, 05:03 PM
Bill's Avatar
Bill Bill is offline
Bill
Porsche3,
Your pads may have the "stars" on the back. These are anti-noise devices and many debates over whether they work. You need to buy a set if you want to replace them. Main point though is that they make it harder to remove the pads if you don't know they are there so flex up. You should do great. Just ask the question if you have a concern--Bill
Old 12-28-2005, 05:15 PM
Porsche3's Avatar
Porsche3 Porsche3 is offline
Porsche3
Thanks for all the input. My last question (for now) is should I get pads from the dealer or should I try more "aftermarket" type pads. The car is driven 1-2 times weekly and will not be used on the track.
2004 Honda Odyssey - Family Truckster
2001 Lexus GS 300 - Daily Beater
1991 Carerra 2 - The one
1998 VW Jetta VR6
1990 944 S2 Sold
Old 12-28-2005, 05:27 PM
RL is right no pins on front. Some ’90 might have them out back though. The star springs are a bitch but if you follow Kurt’s advice and others and push the pads all the way back first it should simplify the process. www.ClarksGarage.com likely has some good directions under the 951 Turbo topics. 964s and 951s had the same front brakes, later 964s also shared the rears. Dude, after market pads for sure
Old 12-28-2005, 07:57 PM
Dealer is going to be expen$ive. Try Mintex, Pagid, or Ferodo. They are available from online retailers (Pelicanparts.com for example) for much less than what the Dealer will charge.
Make sure the pad you choose is appropriate fo the street. Racing pads will not work well until they've heated up.
Also, don't get EBC "Green Stuff" pads. They have great initial bite and good fade resistance, but they are very dusty and they leave deposits on your rotors unless you are always braking very hard. Just my two cents.
Old 12-28-2005, 08:09 PM
Welcome Peter!
There are some good dual use pads [spirited driving on street / DE]. I am sure others with 964s will chime in with their experience. Like was mentioned above ... post you Qs here and we'll be sure to give you some sort of advice ...
FWIW ... I drive a '76 Targa maybe 2-3 times a month and I run Performance Friction 97 "DE" pads.
Cheers,
Jase [aka Jason]
Old 12-28-2005, 08:12 PM
Originally Posted by Jase007
FWIW ... I drive a '76 Targa maybe 2-3 times a month and I run Performance Friction 97 "DE" pads.Cheers,Jase [aka Jason]
Me too including DD
Old 12-28-2005, 09:51 PM
When you stop the car, is the sound roughly the same as a Metro bus? Just curious, becuase the track/street pads I'm too lazy to swap out after each even squeal like a stuck pig on the street when cold (most of the time).
Old 12-28-2005, 10:11 PM
Vertex always has good prices on pads, mintex and their no dust pads work great on the street.
Old 12-29-2005, 08:24 AM
Chopper Dropper's Avatar
Chopper Dropper
964 has the springs, that part is easy. Most carefully remove the sensors, if they break the light comes on. Tie them out of the way and just check your pads visually. If using channel locks etc to push pistons back in, use cardboard or something to avoid marking up your calipers.
Dirk
1988 911 Targa
1986 944
Old 12-29-2005, 09:47 AM
Rick Lee's Avatar
Rick Lee Rick Lee is offline
Rick Lee has one HoF thread
I'd bet Jerry at Euro East has the best prices on brake pads, hands down. PF97's run around $120 per axle, but they sure do stop well.
2023 BMW S1000R
2022 BMW 530i
2021 MB GLA250
