I have the engine ready to remove:
everything is disconnected and clear, and the 4 nuts are removed from the transmission flange. Starter is removed. How hard should I have to tug to get the engine to separate from the transmission? So far, I'm not able to separate the two - but I have not really wrestled with the engine to try to break it free. Before I really tug I thought I'd ask. It's a 1988 with a G50 if that makes any difference.
If you don't go when you wanna go, when you do go, you may find you've already gone. ---------------------- Current: 1999 996.1; 3.4L, ZF 5HP19 Tiptronic, Guards Red w/black interior Past: 1988 930; 1988 911 Targa |
Did you remove the shaft that the clutch release fork pivots on? It's acessible from the driver's side of the transmission. I think it's a 10mm bolt that has to come out, then the shaft will slide out which is holding the engine & transmission together now.
IMO, I would remove both together. It's just as easy. The only extra work is unbolting the axles and taking off the clutch slave cylinder. And if that cross shaft was never out, it's not going to come out easy, and you're going to have a heck of a time getting it out installd in the car. Also, getting the engine and transmission lined back up when re-installing is not the easiest of tasks.
Josh '11 M3 |
Do you have a Bentley manual? It explains engine removal in a very clear way.
Josh '11 M3 |
I agree with taking both out together. It is easier out and easier in. If you don’t you will have to support the end of the trans after the engine is out.
You guys are right. It was much easier taking trans/engine out together.
It took as much time to get the effing cross shaft out of the G-50 as it did to disconnect everything else for the drop. Thanks for the tip on the cross shaft. While on the topic of G-50 cross shafts: mine is an '88 and it appears to have plain bearings - no needle bearings. Is this perhaps already "updated" from the factory. It has brass/bronze plain bearings in the transmission flange ears - and the cross shaft took an M8 bolt to pull it - not an M6 (assuming M6 is 6MM?).
If it doesn't have needle bearings, then it has been updated.....or they all fell out.
2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS |
Congrats on the successful drop ... just remember to save that picture for next year's Holiday Card
1981 911 SC |
Congrats! Are you rebuilding it yourself or sending it out? Looks like a lot of wrenching occured today.
I think I'm going to send it out. I have too little time as it is to spend
at home so that is a factor, plus it seems I can get the rebuild done plus some extra stuff like balancing all the rotating mass for a price delta I can accept. Plus a two year warranty is better than I offer It will be different next season, Steve, with you in a 944 and not being blinded by my smoke in the corners if you are behind me.
Nice work, Emery!!!
A single-handed engine drop??? How un-Dorki. You better have a full blown engine lift party!
-- John Slowly shopping for a 991 or 981... '20 RAM 1500 Laramie '19 X3 |
