#8291
Leaving the neighborhood (in a heavy rain, of course) on Tuesday in my F150 taking my youngest to school, I suddenly lost power steering and got an alternator light. Felt exactly like the engine had died, but still had RPMs on the tach. I figured I'd broken a belt, but when I popped the hood, the belt was still intact. Muscled the truck back home and made some alternate arrangements for the kid, then went and took a hard look under the hood. I could see that the outer rim of the harmonic balancer was a full belt's width forward of all the other pulleys, which caused the belt to jump off behind it. Was going on travel so didn't get a chance to work on it til today. Turns out the outer piece had separated from the center and worked its way almost completely off. When I took it apart the outer piece came off very easily in my hands. I'm pretty lucky that it didn't come completely apart while the engine was running. That outer rim weighs a couple of pounds, and there isn't an easy path out of the engine bay because there is a crossmember right under it with a metal shield running up to the base of the radiator. That piece spinning at 1000 or more RPM would have bounced around in there for a while and destroyed the fan and radiator, and probably some bodywork and the alternator too. I've never seen a failure like this before.
83 911 SC Coupe 75 911S Targa (76 Carrera Look, PO) In theory, there is no difference between theory and practice... |
#8292
What year and how many miles please?
Barry 25 Carrera cab 21 Macan S |
#8293
It's a 1999 F150 4x4 with a 5.4. 196,000 miles.
#8294
At 196K it owes you nothing.
Harmonic failures are not uncommon. Most times it is noticed and fixed at the real bad vibration point rather than the disconnection point.
#8295
Didn't get any vibrations or other warning signs at all. Worked great right up until it didn't. Making the outer ring the driver for the serpentine belt allows for fewer parts than the early V8 engine designs where the pulleys were bolted to the inner section but also puts a lot more stress on the metal to rubber bonding, and has much more interesting failure modes.
#8296
John V 2024 BMW G87 ///M2 (Next 444) 2021 Toyota Supra GR (The Bupra, Other 444) 2016 BMW M235 2015 Porsche Cayenne Diesel 2007 Cayman S, #444 2013 Golf R 2012 BWM x5 2017 Mazda MX-5 Club 3 time DE Parade Lap Champion #BestInstructorEver - Unknown |
#8297
Jeff S '14 991.1 Carrera S Coupe '25 Cayenne E-Hybrid '11 997.2 Carrera S Cab '09 987.2 Cayman S '05.5 Audi S4 '25 GMC Yukon XL '17 718 Boxster '18 718 Cayman |
#8298
I was thinking 'another Mc in the wall'
'64 356 SC '73 914 2.0 (2.8/6 conversion in progress) '65 Ducati Falcon 80 '67 Ducati Cadet 100 4-speed ‘19 SQ5 Gone but not forgotten: '02 S6 Avant - trans blew, but rebuilt as a 6-speed by new owner '99.5 A4 2.8QT - tree fell on it after 20 years ‘74 MB 280C - traded for paint/rust repair/6-conversion mods on the 914 |
#8299
