#21
If you read the rules, it will clearly state that unless it says you can, you can't. In case of removing glass in stock/prepared class cars, it actually says that you cannot replace/remove any except the windshield. Where exactly are these shocks mounted? I have no problem reaching my canisters. As lane said, move them within reach is the best solution
Nader There are 3 sides to every story. Mine, yours, and the truth. 91 944 S2 - Mine, Sold 7? 914-6 Vintage racer - Mine 93 964 - Not mine 95 993 - Hers - Sold and will be missed 04 GT3 - ours? Doing double duties at DE, anyway 06 987 - Hers - plan to let son use for DE - My DIY A few others |
#22
#23
Just leave Spritle and Chim Chim back there to adjust them on the fly. That's the way Speed did it.
Turning good track cars into other people's headaches since 1990 Denis Jenkins (PCA'86) 95 318ti S54 95 318ti CS S50 02 325XIT 02 330i 98 328i 71 911T 72 914 70 Karmann Ghia, 96 f350 7.3 99 StarFlyte 13 C-Max Gone 4 356's,1 996, 4 911's, 1 912, 2 Boxster S, 5 914's, 3 944's, 3 951, 1 924S, 4 95 m3, 03 M3,95 Ti/CS. 97M345, 84 rx7ITB, ITB gti 21, ITB GTI 48, 89 325is s52,07 Z4 coupe, 69 Charger General Lee, 2 66 Cadillac verts, 1 68 cadillac vert, 87 RX7 ITS and others |
#24
All aside. There has to be some way to remote the adjustment or gain alternative access.
#25
I'm open to ideas. The adjuster on the top of the shock takes a 4mm socket.
#26
Flexible shaft extension to an L bracket?
The cabling solution (like for brake bias) might work as well. Nobody tech's these things anyway... replace the floor with thin Lexan and see if anyone notices you can see the track...
#27
possibly. will have to take a more detailed look at the damper and see if there is a way to solidly affix the cable to the 4mm "nut" . the easy approach may end up being with the windows..
#28
Non-racer question here. It says you cannot remove or replace the glass, but can you change how they are mounted? Is that allowed?
Because the original glass is tempered you can't drill it. But... you could bond a bracket onto it that fit onto pins, and put rubber around the mounting area. Quickly pull the cotters from the pins and carefully remove the glass. It would seem that stock tempered glass might survive the ride and removal/installs. Sorry if it's a dumb idea, just trying to think outside the box...
Don Falls Church, VA '78 911SC Targa, aka 'Gizmo' Foolishly optimistic collector of projects, vehicle disassembler and parts hider extraordinaire. |
#29
You mean like mount the glass to an RSR?
#30
Pretty much what I was alluding too earlier. Plenty of other options listed too
