| Other Technical Discussions A place for technical discussions NOT related to Porsche or BMW. Other makes, home DIY, etc. |
#71
Temps of the substrate should be falling during application. Warming concrete exhales. If this is happening while your epoxy is curing, it will bubble and the bond will be hindered.
Try pouring a bit of water on uncoated concrete that is warming. You will hear hissing and see tiny bubbles.
#72
I don't think you need to call in a pro for any garage floor. It is just not that important. RTFM. Going from memory from when I selected and installed the water born rusto stuff the instructions said can be re-coated down the road. This was one of the reasons I selected it. (who am I kidding, I am cheap, it was cheap and looked to be the least finicky of them all)
http://vimeo.com/29896988 “Those that can make you believe in absurdities can make you commit atrocities.” Voltaire. "There is grandeur in this view of life...." Darwin. The mountains are calling and I must go. “The earth has music for those who listen” Shakespeare. You Matter. (Until you multiply yourself times the speed of light squared. Then you Energy) “We’ve got lots of theories, we just don’t have the evidence’. Last edited by Vicegrip; 09-22-2016 at 03:06 PM. |
#73
Dave O'Bryan 1977 911 Carrera 3.0 Targa 1987 VW Westfalia w/ 2002 Subaru 2.5 engine at home , 1991 VW Vanagon Hightop camper in Europe, 1987 VW Vanagon Hightop Syncro camper out West, 2014 VW Jetta TDI Sportwagen |
#74
#75
I've got a thick skin, and he did have some good points.
#76
FWIW the grinding wasnt bad at all. I rent the machine from HD with the fancy bit and it worked well. A little hard to get in/out of the truck alone, but I dont have a loader!
Hard part were the edges since the machine left a bad at the walls. The hand grinding was a bit tedious but not that bad either.
#77
#78
Sunbelt has good selection of latest format grinders that are designed run close to walls and be used by "less skilled operators".
#79
i did my first floor myself. lasted 14 years. i "called the guy" on this one.
Collins Concrete Coatings in Mannasas. great to work with. finish is called Spartacote with a grip additive. ![]() ![]() ![]() ![]()
Marshall ---------------- 95 M3 97 M3 25 M2 Last edited by mlytle; 09-24-2016 at 07:55 AM. |
#80
I resemble that remark mlylte - that looks great
