My new addition the 914 - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » My new addition the 914
Old 06-26-2016, 08:50 AM
rothaus's Avatar
rothaus rothaus is offline
rothaus has nine HoF threadsrothaus has nine HoF threadsrothaus has nine HoF threadsrothaus has nine HoF threadsrothaus has nine HoF threadsrothaus has nine HoF threadsrothaus has nine HoF threads
Hall of Fame My new addition the 914
A few weeks ago I picked up a 914. It's a 76 2.0, Sunlight Yellow.
Here is the mandatory picture.
The car had already major surgery to fix the hell hole, so I cannot take credit for that, as well for the engine rebuild.
Here some pictures from the surgery
The car was converted to Carbs by the PO.
So now it's to start work with some things these car have.
The Tach was not working and I found one for replacement. So, out with the old and in with the working one.
This was a good opportunity to replace the BA7s instrument lights with LED vintage white.
Here before
And here after
The next is the headlights, I cannot believe that people can still drive in the dark with those sealed beams.
There you go.
The backup light was not working, and I ended up to install a new wire from thr backup switch at the tranny to the housing. I didn't want to dig into the electr. panel at this time.
It it is not possible to hide that the car was painted with everything on it.
Also the cable had not chance to hide or escape from the painter.
After opening the rear trunk a few times, it didn't looked right on the left hinge.
Here already removed for repair. The sleeve was broken out from the mounting point
This is how it was installed.
This is how it should be.
OK, lets fix it. Drilling all the way true, and cut the thread.
Weld on an additional nut from the backside.
Ready to weld back in.
Done
Hinge back in, and ready to install the lid.
I will continue to fix all these little enoying things.
More to come.
Cheers
Engelbert
LED Lights for Classic Porsches
2015 911 Turbo
2012 Boxster S
2006 Cayenne S
1982 911 SC
1978 1303 Kaefer Cabrio
1971 911 3.6
Old 06-26-2016, 09:23 AM
B r i a n's Avatar
B r i a n B r i a n is offline
B r i a n
Nice - looks like a fun project.
2024 Lotus Emira FE V6 Manual
2005 Lexus SC 430
2007 Turbo - sold in 2023
1966 912 - sold in 2022
2005 BMW X3 - sold in 2022
1975 Vette - sold in 2015
2004 Cabriolet - sold in 2013
1977 924 - sold in 1991
Old 06-26-2016, 09:49 AM
Yay! Another Rothaus Voyeur Channel! +1 Happiness Level
Old 06-26-2016, 11:50 AM
Patrick3000 Patrick3000 is online now
What he said!
Lucky owner of a couple 911s
1965 Honda Sport 50
Old 06-26-2016, 05:24 PM
BillC's Avatar
BillC BillC is offline
BillC has one HoF thread
Unfortunately, it looks like the repair on the hinge mount is incorrect. The part that you drilled out and re-threaded is actually supposed to fit inside the mount, leaving a flat face on the surface. Then, the bolt that attaches the hinge to the hinge mount is actually a shoulder bolt, and the bolt's shoulder bottoms against the hinge mount and provides the surface on which the hinge rotates.
I just went through this on my '73 914. I had to fix both (L&R) hinge mounts, since both were cracked. Unfortunately, I didn't take any pics because I didn't think anyone would be interested.
Anyway, here's a pic I found on the web of the mount and shoulder bolt:
Old 06-26-2016, 06:35 PM
rothaus's Avatar
Thanks, I will save that picture. This is good to know for the time when I go deeper into the car. This was just a quick fix. I think it make sense to replace both mounts. However, when I studied the torsion spring system, there is a lot of force at that mount. It made me think about a modification and use gas shocks like the 911 have it.
Again, thanks for the info.
Cheers
Engelbert
2015 911 Turbo
2012 Boxster S
2006 Cayenne S
1982 911 SC
1971 911 3.6
Old 06-26-2016, 08:08 PM
BillC's Avatar
You should consider signing up at 914World. It's a forum dedicated to 914s, and a great source of knowledge. The forum is here: http://www.914world.com/bbs2/index.php
Also, there is a vendor called Camp914, and they have kits to replace the front and rear springs with gas struts. I haven't tried them, but they have a good reputation on 914World. Take a look here: http://camp914.com/products.html
Another great vendor is 914 Rubber ( http://www.914rubber.com ). Lots of hard-to-find trim and rubber parts. I've ordered quite a bit from these guys.
Old 06-26-2016, 10:32 PM
little b's Avatar
little b little b is offline
little b
Love this theead!
Looks like a great project!
Brian Pick
66' 911 coupe(Johnson)
Old 06-27-2016, 07:32 AM
Way too high an Fe to Fe2O3 ratio for you. You might have to drive this one around for fun rather than take it down to the pans.
Old 06-27-2016, 08:28 AM
BillC's Avatar
Something else that should be high on your inspect/fix/replace list: Check the fuel lines. If your car still has the original plastic lines, you should replace them ASAP. They have a nasty habit of cracking and leaking fuel. Quite a few 914s have been lost to fuel fires due to cracked original lines. I though mine were okay before I dropped the engine, but one of the lines split as I was disconnecting hoses, which just confirmed the need to do this. There are a couple of vendors making pre-formed stainless steel replacements, or you can fairly easily make some out of brake line.
