Well...I snapped an exhaust stud...HELP! - Dorkiphus.net
Navigation » Dorkiphus.net > Miscellaneous Discussions > Miscellaneous Discussions » Well...I snapped an exhaust stud...HELP!
Old 03-22-2016, 03:33 PM
germanspeed's Avatar
germanspeed germanspeed is offline
germanspeed
Default Well...I snapped an exhaust stud...HELP!
So far I have only snapped one stud although I have been told to expect more. I welcome any suggestions....Anyone have a Stomski Racing head stud tool i can Borrow?
Mark
1992 Red C2
1985.5 944 (sold to Dimi)
1986 911 cabrio (slammed into tree)
Old 03-22-2016, 03:42 PM
Charlie Stylianos's Avatar
I've had very good luck on both snapped and threaded studs using a Snap-On stud extractor (appropriate thread diameter/pitch) with an inexpensive OXY / MAP gas set. Propane will not work here. Get the stud and case around the hole good and hot and it will come out easily.
Kyriakos E. Stylianos
Baglama inspired
Old 03-22-2016, 03:47 PM
germanspeed
Well problem is I snapped it off flush...i don't think that method will work right?
Mark
1992 Red C2
Old 03-22-2016, 05:01 PM
Correct. Machine shop time, unfortunately.
Baglama inspired
Old 03-22-2016, 05:27 PM
I have the Stomski kit for the water-cooled M96/M97 but am pretty sure that is useless on the air-cooled engines as I think they have a different flange layout.
Old 03-22-2016, 05:47 PM
alw20147's Avatar
alw20147 alw20147 is offline
alw20147
I had the same thing happen to me on my brother-in-law's Dodge Charger.
I tig welded a grounded down bolt onto the broken stud. The heat from the tig loosen the sheered off exhaust stud enough that it came out.
Al W.
2001 911 cab
Old 03-22-2016, 06:06 PM
18T_BT 18T_BT is offline
18T_BT
Anyway you can weld on a bolt to it, to see if you can try and turn it to get the snapped stud out? I did that once and it worked for me, time consuming and access to a welder is necessary of course. GL - this is always a major pain...
Val
90-C2-Coupe
Old 03-22-2016, 06:22 PM
When I did this, I snapped off 1 and a former Dorki said "well, you need to take it in anyway so just try to get the rest off" - then snapped off 3 more! Note: on the next engine I worked on, I used a ton of heat, and Kroil, and repeated 3 evenings in a row. All 12 nuts came off without snapping any studs (of course, different engine, different history). Now I use copper nuts (well, I did when I had a Porsche )
With the multiple-snapped-off-stud engine, 2 were flush or close to that, and 2 had threads showing. I loaded it into the back of another Dorki's pickup truck and took it to Matt de Maria, who pulled the 2 showing (with lots of heat) using the tool above, and drilled, cleared the threads, and replaced the other two. He did this freehand (there's a tool that holds the drill perfectly centered and straight) with perfect results.
Old 03-22-2016, 07:24 PM
When I did that I took the piece to Matt at Stuttgart Performance and he worked through it.
Welding on another bolt is another way, though making the bit clean enough maybe a challenge.
