Trying to put a two post lift + standard suburban garage - Page 7 - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Other Technical Discussions » Trying to put a two post lift + standard suburban garage
Old 02-19-2016, 09:31 AM
He's making room for the M5
Same price as the last car I got from you?
Old 02-19-2016, 10:24 AM
XPR-10a is what I have. My only gripes are that the arms are so thick that I have to use a floor jack to get low cars on the pads. The other gripe is that I wish the pads were on threaded supports so I could just spin them to the right height instead of using spacers or blocks. Some day I will actually look into ordering parts to make these upgrades.
But going with the shorter unit is probably easier than what I did which was build a garage around the lift specs.
Old 02-19-2016, 10:30 AM
Seeing your setup is what convinced me to go with the bendpak.
XPR-10A-LP Min pad height: 3.5"
XPR-10A Min. Pad Height: 4"
Doesnt seem like a lot but I hope the extra .5" is all it takes.
Old 02-19-2016, 11:58 PM
mlytle mlytle is offline
mlytle
Originally Posted by dnwong View Post
Time for a group buy!
No kidding. I am nearing point that I will be getting one too.
And a four post version.
Marshall
95 M3
97 M3
25 M2
Old 02-20-2016, 11:15 AM
Good price for a hassle free install. I am thinking about the xpr-10a-lp and may give those guys a call. But I am still months away...
What is the thought on the asymmetric lifts for 911? I see how effective they are for front engine cars. Will they still work properly for back heavy 911? Granted the 911 is not that heavy...
I haven't had any issues with mine. Most shops that I've seen use then, so well proven in commercial use.
I bought 2 2"x12" planks to use as portable ramps. When I take the time to set them in place I have no issues with clearance. Original plan was to cut to fit, drill holes to save weight and add handles like I did to the PCAP ramps. I'll report back if I ever actually get this done
PCAP uses wood ramps to speed the process at techs. Issue with kickback lessened by using carpet runners for approach. Issue with those is if not perfectly placed the lift arms won't swing over ramp.
I've seen some replacement arms for my Rotary that lowers the lift pads even more.
Old 02-21-2016, 12:11 AM
Worth a try. I'm counting nickels and just need to pull some wire.
Old 03-16-2016, 10:43 AM
Gunther's Avatar
Gunther Gunther is offline
Gunther
I used these guys to install my lift and compressor. Fantastic job and a fair price. http://rdsautoequipment.com/
My lift is a 4 post with removable casters that make it mobile. Very happy with the lift and the price paid.
2002 996 Twin Turbo - Speed Yellow
Old 03-16-2016, 11:57 AM
So once the lift is in, then what? Well outside of oil changes and stuff like that, I'm going to need equipment to help with the big removal jobs - rear subframes, gas tanks transmissions, engines, etc. My first thought was to pick up a high lift transmission jack like one of these: http://www.tooltopia.com/sunex-tools-7793b.aspx.
Yesterday I was at Harbor Freight and started looking at one of these instead: http://www.northerntool.com/shop/too...1993_200631993
The down side of the table obviously is that it doesn't go as high. So you have to lower the lift, raise the table, and then squat/sit under the lift to finish the removal. I did find a different version of the same idea that goes a bit higher, but still not to the 70" or so that a full trans jack would get you: http://www.northerntool.com/shop/too...1994_200631994
There are a lot of upsides to the table though. It stores much better in my garage. It's a lot more versatile - I can use it with engine drops as well as transmission work, to lift other equipment for repair (snowblower, pressure washer, etc), it's be nice for lifting engines onto engine stands, and it seems like it'd be a lot more stable.
Thoughts? Anyone have one of these tables in their garage?
Old 03-16-2016, 12:02 PM
The table lift seems pretty useful but I wonder how you would use it for car work. Are you sitting on a stool or the ground? To me a trans jack is one of those things you need with a lift, even if its only used once in a while.
happy with this lift installers?
Old 03-16-2016, 12:10 PM
I've also considered both of these. IIRC the lessor one's handle is fixed. Though fixable a point against it. I also looked at HF alternative to the expensive one you link:
Size:  132.3 KB At under $500 it seems suitable for my purpose.
Edit Problem with these is you end up with a lump relatively high in air. I use my lift arm and sling to raise engines to mount on stand. Engine usually from ATV jack and stand isn't very tall.
