| Porsche & BMW Parts For Sale/Wanted Have Porsche/BMW clutter? Need something for your car? Post For Sale or WTB adds here. Strictly moderated. |
Looking for wheels spacers for a 86 951.
Rear: 10-15mm slip on with no additional studs Front: 1" with studs (so I don't have to replace the current studs on my hub). Needs to have a deep concentric bore to allow for existing nub and grease cap.
Dudley Aldie, VA 99 996 C4 Black/Black Areo 86 951 Graphite / Burgundy 2002 BMW 530i 2008 Volvo XC90 1995 Chev Astro (workhorse going-bald) My Garage Build |
Got spacers, hadn't gotten around to posting for sale:
- 1 pr Techart 20mm w/studs, lug nuts & deep concentric bore - 1 pr Techart 15mm w/studs, lug nuts & deep concentric bore - 2 pr generic 7mm slip-on spacers These spacers were used on my 986 for about 5 years. Also have a full set of 80mm studs w/lug nuts. Haven't researched value, so offer?
Mick '17 Macan Once upon a time: '01 Boxster S '82 RX-7 '72 Alfa GTV 2000 '64 Alfa Guila Spider '60 MGA |
Upper pictures show the rear and outer sides of the Techart spacers. The concentric groove in back is over 1cm deep, and the lip on the outer side is about 1 cm, rounded at the top. With the flat 7mm H&R spacer stacked, there is about 2 cm of non-rounded lip exposed.
The 4th pic shows the Techart with the H&R 7mm stacked on it. The bottom pic is of a 20mm Techart with lug nuts. Stacking would give either 22 or 27mm, depending on whether the Techart used is a 15 or 20mm. Hope this helps.
Does not look like these are going to fit. I need 1 1/8" to clear the dust cap.
I've got some Rennline 15mm spacers available. Bought for my wife's Boxster, and ended up not needing them.
Rob T. 2006 Carrera S 2013 Cayenne GTS |
Ok. Ended up taking my old spacers and having them modified by a local who had a impressive machine shop in his garage.
IMG_2199.JPG IMG_2210.JPG Now I have to decide if that is the correct look vs my original cup 1s. IMG_2201.JPG
