2001 Boxster S Engine (M96/21) Rebuild - Page 3 - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » 2001 Boxster S Engine (M96/21) Rebuild
Old 12-02-2014, 06:43 PM
987kmns's Avatar
987kmns 987kmns is offline
987kmns has five HoF threads987kmns has five HoF threads987kmns has five HoF threads987kmns has five HoF threads987kmns has five HoF threads
Originally Posted by ausgeflippt951 View Post
Question: do you actually own any non-Porsches?
No.
Mihnea
2007 Cayman S Track Car
2004 911 GT3
2016 Cayenne S
2017 Macan S
2008 Cayenne S - Sold
2011 Boxster S - Sold
2007 Boxster S - Sold
2001 Boxster S - Sold
Old 12-02-2014, 09:15 PM
ruffyz ruffyz is offline
ruffyz
Originally Posted by 987kmns View Post
No.
Good man.
Thanks for the post, I'm actually kinda looking forward to my own rebuild in what I hope is 100k miles from now.
Old 12-02-2014, 10:48 PM
Rob VN's Avatar
Rob VN Rob VN is offline
Rob VN
Mihnea,
Thank you for the link to your Cayman engine drop and the tip on rotating the engine 90 degrees. The Sears ATV lift is on my Christmas list. Good luck with your engine refresh. Looking forward to your progress.
Rob
2014 Mazda 3 DD
2015 Cayenne Diesel
2016 Spyder
Old 12-03-2014, 12:39 AM
987kmns's Avatar
Tonight Ion and I removed all the pistons, rods, and separated the crankshaft carrier.
Pistons and rods:
Here is the #6 rod:
There is some wear on the thrust faces, so new bearing caps are in order.
Crankshaft carrier:
Bolts backed out:
And separated:
Again, I was surprised by the great condition of all the parts. I will also order new crankshaft bearing caps and shims. I'm already very excited to start the assembly. Hopefully, I can finalize the parts list tomorrow and make the order.
Thanks for all the interest and encouragement everyone!
Mihnea
2004 911 GT3
2016 Cayenne S
2017 Macan S
Old 12-03-2014, 12:48 AM
987kmns's Avatar
Originally Posted by Rob VN View Post
Mihnea,
Rob
My pleasure! I just remembered that I had to remove the pressure plate and clutch disc in order to get the engine to squeeze in between the subframe members. With it off, you have the perfect amount of room for the engine to come out. It's not a big deal to undo the pressure plate under the car. Likewise when you reinstall everything.
Please let me know if any questions pop up when you tackle this job. I would love to help with whatever advice I can provide, although based on your work I've followed on P9, you are light years ahead of me. I actually drew a lot of inspiration from you projects for my own track car.
Mihnea
2004 911 GT3
2016 Cayenne S
2017 Macan S
Old 12-03-2014, 01:44 PM
ausgeflippt951's Avatar
Shock Whisperer
Wow, by and large everything looks really good. Right on!
Collin M.
I wear a cowboy hat.
'06 M3: hers.
Old 12-03-2014, 02:03 PM
Good call on the rebuild given the bearing surfaces (looks like some clutch riding was going on). This was the 'full tear down' I was asking about The circlip insertion on #6 will be the fun part. I have the tool set (it looks like you may as well) and the bore scope needed to avoid any awkward moments on first spin up
Old 12-03-2014, 02:29 PM
987kmns's Avatar
Hahahahaha. "Awkward moments." Love it. I sure hope not!
I have a rebuild tool set that should have the circlip tool. I was planning on practicing a lot before doing the 4-6 bank piston circlips. Ion keeps bragging that he has a USB bore scope, but he hasn't substantiated his claim yet. I have a set of mirrors that I've seen people use sometimes as a low tech solution.
What do you mean about clutch riding and how does that affect the bearing surfaces?
Mihnea
2004 911 GT3
2016 Cayenne S
2017 Macan S
Old 12-03-2014, 02:49 PM
Shock Whisperer
What's the 4-1-1 on the #6 circlip? I'm not familiar with this but would like to understand why it's special.
Collin M.
'06 M3: hers.
Old 12-03-2014, 02:59 PM
987kmns's Avatar
So for the 1-3 pistons crankcase half, you install the pistons the way you would on any engine - by slipping the piston and rod (with wrist pin and circlip installed) into the bore and bolting the rod bearing cap onto the crankshaft. For the 4-6 crankcase half you can no longer do this as you already bolted the case halves together, so you don't have access to the crankshaft anymore.
What happens instead is that you bolt the 4-6 rods to the crankshaft first and now you have to push the pistons into the bores and slip the wrist pins and circlips through an access hole in the case wall.
Have a look here:http://www.flat6innovations.com/inde...owall=&start=3 starting with the 6th pic down and continuing onto the next page. This is generally why folks regard an M96 rebuild as difficult, in addition to the somewhat complex timing. I'm sure this is all a little more straightforward once you do it once or twice.
Mihnea
2004 911 GT3
2016 Cayenne S
2017 Macan S
